Home > Maintenance & Modifications > Active Roll Control Module
Pufftmw
Well, apparently mine is stuffed and I need a new one Sad
According to a Landrover dealer, you need to buy a new one as they need to be programmed to the car, so you can't use a second hand one - is that correct?
Anything else I should be knowing about this?
Car had Suspension Lean fail and orange light on dash. We've checked the compressor and that's all fine, changed a couple of rear ride height sensors, put my AT3s back on (instead of the remould MTs) but it now won't calibrate for ride height.
Post #580694 Sun May 12 2019 3:36pm
i would try and 2nd hand one if cheap
Post #580696 Sun May 12 2019 4:16pm
The Dynamic Response Control Module contains two tunes - one for the TDV8, the other for TDV6 and petrol versions. Presumably the weight of the TDV8 is sufficient to require a different set up. The choice of tune is selected when the module is first installed. I wonder if this is what they are referring to. It might be worth trying a 2nd hand TDV6 one if you can find one cheap enough. Obviously avoid one from a TDV8 in case the tune choice is a one shot deal. 2012 SDV6 - it's missing a couple of cylinders
Post #580758 Mon May 13 2019 5:21pm
not all TDV6 had active though.
Post #580765 Mon May 13 2019 6:16pm
Then there won't be a module to fail, will there? Whistle
Dynamic Response Control Module is what the "active roll control module" is. It's separate to the air suspension control module. The former is on the passenger side above the footwell, the latter is above the driver's footwell (on RHD). 2012 SDV6 - it's missing a couple of cylinders
Post #580771 Mon May 13 2019 8:19pm
Brit Plumber
Re: Active Roll Control Module
Even a second hand one can be reprogrammed! It’s just an EPROM so worst case is just need a reflash. Why are they saying the module is stuffed? 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #580801 Tue May 14 2019 11:34am
Pufftmw
Lean error on the dashboard with
Active Roll Control
C1A00-01 (AF) Control module - General failure information - general electrical failure
( at 251558 km )
Another device used also says a similar thing & my indy had someone else check, who said the same thing.
Car noticeably (RRSTDV8 following) leaning on corners over what you'd expect standard (feels a bit rolly too). Compressor works as should and has been "serviced". Rear roll/height sensors replaced as well as rear arms.
All wiring correct and undamaged. Both ARCs working 100% with no fluid leaks.
Car won't calibrate ride height.
Post #580802 Tue May 14 2019 11:51am
It did look like it was permanently on a side slope in Wales! Laughing 2012 SDV6 - it's missing a couple of cylinders
Post #580803 Tue May 14 2019 11:53am
Brit Plumber
Is it defo C1A00-01 as that code suggests an issue with the wiring harness or damaged isolation switch. -04, 43,45,46 would be associated with a module internal failure. Have you checked the plug at the terrain switch? 2019 5.0 SC SVA (Current)
Post #580844 Tue May 14 2019 9:42pm
Pufftmw
That's what came up on IID that I captured back in Feb though they have subsequently used another tool(s) to come up with their prognosis. The wiring & plugs have all been checked.
Post #580869 Wed May 15 2019 11:28am
