Home > Technical > 2012 RRS (1piece tailgate) - Boot sticking ?
Autobiography1969
Sorry to jump in but is there a how to for this upgrade?
I found the part but just wanted to know how easy it is,
Would be interested in it myself.. ===========================================
2012 Range Rover Sport Autobiography 3.0 SDV6 8 speed Automatic
Indus Silver with Hockenheim premium two-tone leather Ebony/Lunar,
Post #580184 Fri May 03 2019 2:24pm
Have a look at this in my gallery File 1 03/05/19, fitting instructions for original version, if new one now plug and play should be even easier as no soldering wires.
[img]http://www.rrsport.co.uk/gallery/albums/userpics/16610/2012-%20RRS%20Tailgate%20Closer%20Unit%20Fitting%20Guide.pdf[/img]
Post #580211 Fri May 03 2019 9:51pm
Brit Plumber wrote:
Yeah that’s the first version, the new version is plug and play so it may be the new version which has a timing issue, not a fault, just something that happens if you accidentally (whether you know it or not) press the unlock button twice.
Out of curiosity operated the buttons on mine twice in quick succession and that releases the tailgate lock, it then stops opening, if I press button twice but a little slower it opens then closes again, does the same on all three buttons, fob, dash and tailgate never ever noticed before, but then again don't recall ever pressing the buttons twice. But as I say though nothing to do with my original problem as was doing it before mod fitted.
Post #580213 Fri May 03 2019 10:22pm
Autobiography1969
Thanks Col..
A bit of light reading..
yes the new one is plug and play,, so as you say should be a bit easier.. ===========================================
Post #580215 Fri May 03 2019 10:39pm
Brit Plumber
It takes longer to remove the back panel than it does to fit the device. Just don't use the sticky pad wire fixings as mine kept falling off so gave up with them. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #580320 Sun May 05 2019 10:03pm
mrluke
Ok tried opening the boot again yesterday with the key. Same thing again , opens a little bit then stops.
I bought a new microswitch/handle for the boot so will fit that and at the same time remove the key closure mod and see if that helps.
Post #580340 Mon May 06 2019 12:07pm
mrluke
Ok Managed to get some time to do this today,
First i removed the mod inside the tailgate ( one that allows the boot to close from the key)
I then decided as per col's suggestion to replace the switch also , was cheap so worth a try . Plus i think i had this problem before i had even installed the rear tailgate mod.
I never new the silver piece wasnt seperate, it actually removes the rear badge also !
The old switch had some bare wires with a sleeve on them ? my new replacement switch does not.
All good for now , will try tomorrow after work when it "hopefully" has been baking in the sun for a bit.
Thanks all for your help ! if the boot continues to work correctly i will reinstall the remote control close mod and see what happens.
Also if attemping to do this , make sure you have a endoscope with a magnet attachment ! . Saved my behind when i dropped one of the bolts in the tailgate, you have no access really to the bottom unless you use something like a endoscope.
Post #581072 Sun May 19 2019 10:42am
mrluke
Ok a few weeks on..
Boot has started to stick again , sometimes it gets stuck around 5cm from latch .... But yesterday got stuck half way .
If i press the key again it opens fully.
As this is the one piece tailgate , i assume the following could be faulty
Latch ( i assume this has the actuator inside it ? )
Struts ?
Is there any sensor that detects if its hit something and stops the tailgate ?
Anything else ??
Please help Very Happy
Post #581968 Fri Jun 07 2019 11:13am
Brit Plumber
You could try cleaning the strut inner (piston?) with a spirit or similar and then lubricating. My struts started making annoying noises so I cleaned and applied Vaseline then opened and closed the tailgate to work it in. There has to be a resistance sensor as it stops opening if it hits an object or the person opening stops it. Perhaps friction in the hinge and strut is tripping this sensor or your struts are tired and losing power. My struts were replaced under warranty before I purchased the vehicle so I’d imagine if yours are original, they could be tired. 2019 5.0 SC SVA (Current)
Post #581987 Fri Jun 07 2019 7:54pm
mrluke
I think im gonna try the Struts next .
Not massivly expensive .
even if i have to replace Struts , Motor and latch .. Still has to be cheaper than paying a garage to problem solve it !
Post #582160 Mon Jun 10 2019 10:04am
Brit Plumber
Have you tried cleaning them?
You could also try giving them a little help up to see if that stops the fault. It may give you a warm feeling it’s the struts....or not. 2019 5.0 SC SVA (Current)
Post #582166 Mon Jun 10 2019 12:17pm
mrluke
Ill be honest , Its so Random i dont even know when it will happen again so might just replace the struts and hope for the best.
If it isnt, the motor will be next.
Post #582171 Mon Jun 10 2019 2:06pm
