Home > Technical > 2.7 Cambelt tensioner question
Cu11eyx
United Kingdom 2012 Range Rover Sport TDV6 HSE Bali Blue
Hi quick question I've changed my cambelt today 2.7 tdv6 done lots of belts on different makes and models in the past just the cambelt tensioner had me check twice when building it up. The question is: do you put the tensioner on, tension the belt then tighten it once it's at the correct tension indicated on the tensioner? , the reason I ask is on VW's and Audi's with a similar style tensioner they have a locking tab that locates on the block to stop the tensioner turning once it's tensioned and tightened if this makes sense? The land rover one doesn't seem to have anything like that..I've built the car back up and it runs fine just keep thinking hope that tensioner is correct! (Genuine land rover kit used) PS I looked at the "How to" on this site before starting Thumbs Up
Post #579694 Fri Apr 26 2019 6:22pm
Cu11eyx
This is an example of the vag tensioners with the bit that hooks into the block. With that hooked in position it would help stop the tensioner spinning and loosing tension. Obviously the bearing part of the tensioner spins.
I'll get a pic of the land rover one tomorrow
Post #579719 Fri Apr 26 2019 9:47pm
I think it’s ok.
Use Allen key to apply tension
Tighten bolt using torque wrench. Not too tight.
Rotate engine couple of times.
Ensure tension arrow at correct position.
Post #579724 Fri Apr 26 2019 10:25pm
Camelrock
Yes it’s ok they don’t have a locking tab like the VW 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
2018 Discovery 5 HSE lux current
1994 Dakar current
Post #579836 Sun Apr 28 2019 11:02am
Cu11eyx
Thanks for the reply's Thumbs Up
Post #579854 Sun Apr 28 2019 5:35pm
