![]() | Home > Technical > 2.7 Cambelt tensioner question |
Cu11eyx Member Since: 02 Jan 2019 Location: Teesside Posts: 22 ![]() ![]() ![]() |
This is an example of the vag tensioners with the bit that hooks into the block. With that hooked in position it would help stop the tensioner spinning and loosing tension. Obviously the bearing part of the tensioner spins.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5118 ![]() ![]() ![]() |
I think it’s ok.
Yes it’s ok they don’t have a locking tab like the VW 2008 G4 RRSport TDV8 current
Thanks for the reply's |
