![]() | Home > General > Rear upper arm bolt seized |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4527 ![]() ![]() ![]() |
Cut the bolt, and replace the bush |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402 ![]() ![]() |
Cheers DM,
MGO Member Since: 29 Jan 2011 Location: Leinster Posts: 156 ![]() ![]() ![]() |
if you are replacing the bush on the hub then it doesnt matter what you used to cut it.
