Home > General > Rear upper arm bolt seized
PC76
Hi all, a little advice please.
I was trying to replace my rear bearings last night and failed because the top bolt which hold the hub on to the upper arm had seized in the bush.
Is heating the best way to remove this and if so what’s the best method?
Thanks
Post #577357 Tue Mar 19 2019 2:54pm
Disco_Mikey
Cut the bolt, and replace the bush Thumbs Up
Post #577360 Tue Mar 19 2019 3:10pm
PC76
Cheers DM,
what do you use for cutting the bolt. i have seen various tools used and plenty of tools using them......lol
Post #577361 Tue Mar 19 2019 3:27pm
MGO
Ireland 2012 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
if you are replacing the bush on the hub then it doesnt matter what you used to cut it.
i used skinny 4" angle grinder disc last time i did mine.
cut out both sides but the bolt was still seized solid in the bush.
didnt have spare bush with me... so i drilled the bolt out then used freeze spray to get it all out. 2007 TDV6 RRS HSE..now gone
2012 3.0 SDV6 RRS HSE
Post #577362 Tue Mar 19 2019 3:31pm
