![]() | Home > General (L494) > Disappointing Dealer! |
hoppy_70 Member Since: 28 Mar 2009 Location: United Kingdom Posts: 437 ![]() ![]() ![]() |
Changed my front pads last weekend but found myself with the brake warning light left on, even with a new sensor wire. Bought another cable thinking it must have been a dodgy cable, only to find that the light stayed on. Had already checked the back and found no sensor fitted. Thanks to Andy (tyrefitter) confirming there should be one, had another look. Found the sensor detached, broken and tucked away behind the brake. Must have corroded or degraded over time, causing the light to come on.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9136 ![]() ![]() ![]() |
Not at all surprised. Which is a damning indictment of LR dealerships, sadly. 2012 SDV6 - it's missing a couple of cylinders
gtr_skyline Member Since: 28 Apr 2018 Location: St Albans Posts: 245 ![]() ![]() |
Sorry to hear...worrying if they are so bad with a routine service item - god only knows how they attempt to fix more complex issues MY16, 3.0D HSE Dynamic, Barola Black, TV, Rear Entertainment, Opening Pan Roof, Meridian |
My experience of a particular LR dealership is that complex stuff leads to other things being damaged. I had to have a new steering rack and lower column fitted after having turbos replaced. I guess they forgot to separate the steering column before lifting the body. Let me drive away with it damaged too, so obviously there was no test drive after doing the work - or they just didn't care and let it go out anyway.
I hear grange Welwyn used to outsource complex work to a reputable local Indy MY16, 3.0D HSE Dynamic, Barola Black, TV, Rear Entertainment, Opening Pan Roof, Meridian |
Reputable Indy would probably sack a technician for such skullduggery! Too damaging to their reputation and was ALWAYS going to be found out when the pads needed changing. Assholery at its finest and cost me £25 in cables to figure out! Range Rover Sport HSE DYnamic SDV6 Velocity blue 2020 MY
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2021 ![]() ![]() |
I’d be round there voicing my complaint in a raised voice. Soon gets things sorted when prospective buyers can hear you |
