Home > General > hi i need some help spare wheel |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 869 |
Copy of my post from a while ago. Easy fix. Raise car to offroad height to give some room to crawl under
Fri Feb 01 2019 4:43pm |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1848 |
Did you wind it up without tension on the cable? As said above, try winding it out, keep it under tension and wind in again. 2012 5.0 SC AB
Fri Feb 01 2019 9:24pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4844 |
This is what you are after if you can't repair your own, just get the later type with the metal part protecting the lower spring, supposed to help prevent the cable being cut by some scroat thieving your wheel, not sure if it does though.
Fri Feb 01 2019 9:56pm |
ashleighash Member Since: 13 Apr 2018 Location: fulham Posts: 25 |
thankyou i will give this a go |
Sat Feb 02 2019 10:45am |
hi im not sure as i took it to tyre shop they did it told me there is nothing they can do about it its common on these cars !!! |
Sat Feb 02 2019 10:50am |
215m3 Member Since: 13 Sep 2018 Location: Cambridge Posts: 48 |
I had this on mine. I did undo the 4 bolts holding it on and even with a pry bar it was still on tight. Got it covered by the warranty anyway. 2010 3.0 TDV6 RRS Overfinch GTS
Sun Feb 03 2019 9:47pm |
