Home > General > Wading
Timf
RRSTDV8 you have the same mind-workings as me.... Wink
Post #574210 Fri Feb 01 2019 10:19am
HughN
Wales
And, for you both, the answer is "yes".
Post #574211 Fri Feb 01 2019 10:20am
Timf
HughN...dreaming again?! Laughing
Post #574216 Fri Feb 01 2019 11:19am
Themoog
United Kingdom 2005 Range Rover Sport Supercharged Rimini Red
But what about water in the transmission or diffs? They have vents so are they high up or one way valves or something?
Just asking.
Post #574262 Sat Feb 02 2019 12:46am
On the RRS, the front diff vent is up behind the radiator with a valve on it, the gearbox and transfer box vents are up behind the engine block, no valves, and the rear diff vent is up by the fuel filler, again no valve. Only the front needs a valve because of the bow wave - if you've got water up around the others, you're probably already in "killing it" territory. 2012 SDV6 - it's missing a couple of cylinders
Post #574279 Sat Feb 02 2019 10:06am
Themoog
I knew that. I just forgot.
Post #574317 Sat Feb 02 2019 3:05pm
