![]() | Home > General > Wading |
Timf Member Since: 27 Feb 2010 Location: East Anglia Posts: 312 ![]() ![]() ![]() |
RRSTDV8 you have the same mind-workings as me.... |
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 ![]() ![]() |
And, for you both, the answer is "yes". |
HughN...dreaming again?! |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9086 ![]() ![]() ![]() |
On the RRS, the front diff vent is up behind the radiator with a valve on it, the gearbox and transfer box vents are up behind the engine block, no valves, and the rear diff vent is up by the fuel filler, again no valve. Only the front needs a valve because of the bow wave - if you've got water up around the others, you're probably already in "killing it" territory. 2012 SDV6 - it's missing a couple of cylinders
Themoog Member Since: 27 Apr 2018 Location: Cambridge Posts: 262 ![]() ![]() ![]() |
I knew that. I just forgot. |
