Home > Technical > Electrical problems, heated screens/seats
Dave Pitt
United Kingdom 2005 Range Rover Sport TDV6 HSE Zambezi Silver
Hi, Having just become the owner of a RRS, as the weather turns freezing it has become obvious that the heated screens, heated seats and fuel burning heater don't work, is there anything common to these systems? I was warned they could be a pig electrically....
Post #573614 Tue Jan 22 2019 10:20am
FBH. May need resetting. If you don't have a fault code reader, remove the FBH fuse for 1 minute and refit.
Windscreen - THese do fail, although one side usually works.
Rear window. - The wire can break near the top spoiler. THe 2 thick wires
Seats - does the passenger work?
Do the switch lights come on for the above?
Don't turn everything on at once. If there is a battery/alternator issue it could be shutting these items off.
Post #573617 Tue Jan 22 2019 1:05pm
Dave Pitt
Thanks for the swift response, the switches do light up, whats the fuse I need to pull?
Post #573618 Tue Jan 22 2019 1:13pm
F28 under the bonnet. (the tiny fuses)
a yellow one
Post #573620 Tue Jan 22 2019 1:50pm
Oldandconfused
Have you tried giving the battery a good charge? If it's low or on its way out there may not be enough current to go round.
Post #573624 Tue Jan 22 2019 2:44pm
