![]() | Home > Technical > Electrical problems, heated screens/seats |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5052 ![]() ![]() ![]() |
FBH. May need resetting. If you don't have a fault code reader, remove the FBH fuse for 1 minute and refit.
Dave Pitt Member Since: 22 Jan 2019 Location: North Yorkshire Posts: 2 ![]() ![]() ![]() |
Thanks for the swift response, the switches do light up, whats the fuse I need to pull? |
F28 under the bonnet. (the tiny fuses)
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 782 ![]() ![]() ![]() |
Have you tried giving the battery a good charge? If it's low or on its way out there may not be enough current to go round. |
