![]() | Home > General > Heated screen |
the_big_1 Member Since: 04 Jul 2014 Location: Warwickshire Posts: 577 ![]() ![]() ![]() |
Hi guys,
It is a fault, both sides should clear at the same time and speed. The passenger side failed on my last RRS after only 14 months so the screen was replaced under warranty, but you have a faulty screen so demand the installers have a look at it - it may be the connections but it could be a broken element. They are connected separately to reduce the load That one huge element would place on the battery/ alternator so it could be that the fitters are unaware that there are two sections to connect up.
1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530 ![]() ![]() ![]() |
It could be a faulty screen but you need to check a fusible link to that side before you do anything.. |
Bill Portland Member Since: 01 Feb 2017 Location: Dorsetshire Posts: 395 ![]() ![]() ![]() |
each side of the screen is on a separate fuse. Had one blow on mine (it's quite common apparently). Check the fuses.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5096 ![]() ![]() ![]() |
I think the OP has a RRS2, can't even see fuses listed in any of the fuse boxes for it but must be there somewhere I imagine.
If it is the grey car shown in the photos in his gallery then it is an L320 RRS 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Going by his recent posts he had, or has a 2015 RRS2.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5096 ![]() ![]() ![]() |
If only there was some way we could tell what car he has? |
Funny, I had exactly the same this morning on my L320, drivers side fine, passenger side, zilch. I suspected a fuse as I can see the fine wires and it would be unusual for them all to blow. My old Focus lost a few elements over its 15 years but the good ones always compensated. 2019 5.0 SC SVA (Current)
The can fail at the bus bars stopoing one side.
Was a know fault on MY12 & MY13 cars, TSB/Service Action about it if I remember correctly they fitted different type "J" fuses.
Col, any ideas which fuse numbers these fuses are? I can’t find them in the book and what I found online appears to be L322. 2019 5.0 SC SVA (Current)
Engine bay fuse box, looking from front of car they are in a bank of six fuses located to the rear and slightly left, sort of pink square 30amp rated ones, fuse position 2 is right hand side and six is left hand side.
Cheers Col, sure enough the left side fuse was blown. I had to take the cover of the fuse it’s self to see that both legs had blown. 2019 5.0 SC SVA (Current)
