Home > General > Rubber Strip
RRSRobC
Rubber Strip
Evening,
The rubber strip between the windscreen and the roof has just flown off on the M40. How vital is it and where can I buy a new one? 2007 L320 3.6 TDV8 HSE Java Black
2010 W204 C350 AMG Black
2007 E93 325i M Sport Black II
2004 E46 330ci M Sport Black II
Post #534487 Sun Sep 03 2017 10:12pm
About 10 quid from L/R or were, it's only really cosmetic but act's as a seal for water as well, may also help stop some wind noise I suppose.
Post #534489 Sun Sep 03 2017 10:36pm
Socast
I wasn't aware of any trim between the roof and the windscreen, just the bitumen/glue that holds the screen in place Question
There's two pieces of trim attached to the A pillars and the scuttle at the bottom of the screen. If it's one of the trims off the A pillar then you will need to cover all the holes with tape (until your new trim arrives) otherwise you'll find water in your foot wells Thumbs Up
Post #534504 Mon Sep 04 2017 12:25pm
It's a piece of rubber LR032336 that goes across the full width of the roof and is stuck to the top edge of the sceen with double sided^ 3mVHB tape.
Post #534505 Mon Sep 04 2017 12:32pm
RRSRobC
Thanks. It had come off before but managed to catch it through the sun roof before it flew completely off. I'll get another one ordered up. 2007 L320 3.6 TDV8 HSE Java Black
Post #534510 Mon Sep 04 2017 1:08pm
Might be worth using some L/R STC50550 adhesive to help stick in place, it's actually a Loctite product so if you could find there equivalent it will probably be half the price.
Post #534512 Mon Sep 04 2017 1:19pm
Socast
I stand corrected Smile
Post #534517 Mon Sep 04 2017 1:51pm
