![]() | Home > General > Rubber Strip |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5087 ![]() ![]() ![]() |
About 10 quid from L/R or were, it's only really cosmetic but act's as a seal for water as well, may also help stop some wind noise I suppose.
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
I wasn't aware of any trim between the roof and the windscreen, just the bitumen/glue that holds the screen in place |
It's a piece of rubber LR032336 that goes across the full width of the roof and is stuck to the top edge of the sceen with double sided^ 3mVHB tape.
RRSRobC Member Since: 31 May 2017 Location: Laleham, Surrey Posts: 23 ![]() ![]() ![]() |
Thanks. It had come off before but managed to catch it through the sun roof before it flew completely off. I'll get another one ordered up. 2007 L320 3.6 TDV8 HSE Java Black
Might be worth using some L/R STC50550 adhesive to help stick in place, it's actually a Loctite product so if you could find there equivalent it will probably be half the price.
I stand corrected ![]() |
