Home > Technical > Dead as a Dodo, input and thoughts welcome.
Stuart
Driving last night, I stopped at a shop and when I got back in the starter just groaned like a flat battery.
I had some jump leads in the car, so collared a nearby person for a jump start and we were in business again.
I had to make another stop on the way home, so of course left the engine running for the five minutes that took. But during that period of idling (in Park) the dash lit up like a Christmas tree, suspension fault, park brake fault, special programs off, all the usual things they do when unhappy, and the damn thing then locked itself in Park and I couldn't pull away. Shocked
Logic told me that whatever was causing the lack of electricity probably helped lock it in Park? So I turned it off, got another jump start, and this time it came out of Park and I limped the five minutes home. I say limped as the gearchange was up the wall, felt like it pulled away in third. On that five min drive home, apart from all the bonging and warning lights, the dash lights started flickering and went out. It limped onto the drive like a torpedoed boat. Laughing
The car had a new battery a couple of months ago (not an expensive one from a big brand but right spec and no issues since). For me, if the battery was duff and the alternator OK, it wouldn't have the dash lights fading and locking itself in Park? It should be powered up when running.
I haven't meter tested it while running yet, I wanted to charge the battery first tonight and see if all the warning lights go off.
Is the dreaded brake light switch a likely factor here? It's never had one while I have had it the last 3 yrs or so, so I ordered one anyway today from AF.
For me, the evidence is pointing towards an alternator, which I suppose will be known when I see what its putting out when running tomorrow. That being the case, is AF the way to go for one of those? Or are recons OK? Or can one just change the reg box like alternators of olde?
Does anyone else have experience of the car locking itself in Park? Or the gearchange going up the wall in similar circumstances? Is the gearchange electrically controlled? Get a 2005-2009 RRS (FAH500210) sat nav/dash mat here - the one that wasn't there when you bought the car.
Spiffing wheel centre caps available
Post #528852 Fri Jun 23 2017 6:08pm
geoffsnook
So no battery light on before hand Question if the alternator is knackered it may well have taken the battery out as well .You need to see what power it is putting out when the car is running with everything inside turned off and then with everything turned on Thumbs Up
Post #528865 Fri Jun 23 2017 7:40pm
Stuart
No, there was no advance notice of a fault beforehand at all.
I'd expect the only way an alternator can take out a battery is if it's overcharging, and you can usually smell that. And I couldn't. Get a 2005-2009 RRS (FAH500210) sat nav/dash mat here - the one that wasn't there when you bought the car.
Post #528870 Fri Jun 23 2017 8:23pm
Hocks172
Going on some other threads that I've read on the d3 forum it sounds like the alternator? Id get that and the battery tested to rule them out. RRS Autobiography SDV6 19
Tesla model 3 long range SOLD!
BMW f15 X5 m50d SOLD!
Disco 5 HSE Lux SOLD!
Evoque Dynamic Lux. SOLD!
RRS HST Sold!
Other gonners, Disco 3, BMW 525d E60, Jag 2.2d X-Type, Merc E240, Audi A4, Peugeot 306, VW Golf GTI 1.8T mk4,Toyota Hilux, Mazda 323f, Escort 1.3!
Post #528887 Sat Jun 24 2017 8:42am
squizzel
There was no smell off mine, the car just cut out. Everything went dead, no lights, no advanced warning nothing. It was the alternator and it took a new battery out with it. We put a jump starter on it to get it running and drive it onto the recovery truck, and it completely flattened that in 3 minutes.
Post #528889 Sat Jun 24 2017 8:58am
Terrye
United Kingdom 2007 Range Rover Sport TDV6 HSE Siberian Silver
Check your battery are clean and tight.
Smean a small amount of valine on the battery posts mate.
This costs nothing.
Last winter my wife was driving the car to work and had very similar issues as you are reporting.
As an electrical engineer I also intially assummed alternator and or battery problems however after testing alternator output and battery voltage I started to dig deeper.
If battery terminals are not clean and tight a huge amount of resistance and therefore current at this point occurs which cannot really be seen by naked eye.
Best to clean them up just in case.
Post #528900 Sat Jun 24 2017 11:35am
Stuart
So I charged it overnight, it started fine with no warning lights.
With the engine switched off the battery reads 12.4v, after starting, that drops to 11.4v. I'd expect to see something around 14v if it was charging normally. That says to me the alternator isnt charging and is in fact draining it a volt or so.
Would the good folks here agree this sounds like an alternator? Get a 2005-2009 RRS (FAH500210) sat nav/dash mat here - the one that wasn't there when you bought the car.
Post #528924 Sat Jun 24 2017 4:40pm
geoffsnook
I would say so Thumbs Up
Post #528926 Sat Jun 24 2017 4:49pm
Stuart
Ordered one, so we'll see. I expect that'll fix it. Get a 2005-2009 RRS (FAH500210) sat nav/dash mat here - the one that wasn't there when you bought the car.
Post #528932 Sat Jun 24 2017 5:25pm
Stuart
So the alternator seems to have fixed it, but I have a question.
The gearchange seems up the wall, the car seems even more sluggish than usual. Doesn't seem to want to pull away with any guts (even if I manually select 1st) but picks up when it gets to maybe 10-20 mph.
Does it need to "relearn" my driving style as the battery has been disconnected? Or is something like a loose hose or air pipe disturbed during alternator fitting more likely? Get a 2005-2009 RRS (FAH500210) sat nav/dash mat here - the one that wasn't there when you bought the car.
Post #529348 Fri Jun 30 2017 4:54pm
geoffsnook
Try a hard reset first to see if that cures it Thumbs Up
Post #529353 Fri Jun 30 2017 5:33pm
Stuart
Did a hard reset this morning and it was a little better, but on driving I decided that the turbo wasnt kicking in.
One of our vacuum engineers (an ex diesel fitter) had a poke about under the bonnet and found a plug was unplugged near the air filter (presumably left off in error by the garage who fitted the alternator). He retrieved it from the engine bay, plugged it back in and the car is back to normal.
Happy days. Thumbs Up Get a 2005-2009 RRS (FAH500210) sat nav/dash mat here - the one that wasn't there when you bought the car.
Post #529414 Sat Jul 01 2017 4:29pm
Johnski
I hate service garages that don't check your car is all working after repairs. Embarassed
Surely even a two minute drive and stationary check for the rest, would sort these problems.
I'm sure this would have been picked up on a LR test unit, or your own GAP IID BT tool, if you have one. Wink John
Post #529421 Sat Jul 01 2017 8:42pm
