| RRSPORT.CO.UK | ||
|  | Home > Technical > Dead as a Dodo, input and thoughts welcome. |
| Stuart Member Since: 17 Oct 2013 Location: Manchester Posts: 581      |
 Driving last night, I stopped at a shop and when I got back in the starter just groaned like a flat battery.
|  Fri Jun 23 2017 5:08pm |
| Stuart Member Since: 17 Oct 2013 Location: Manchester Posts: 581      | No, there was no advance notice of a fault beforehand at all.
|  Fri Jun 23 2017 7:23pm |
| Hocks172 Member Since: 01 Dec 2016 Location: Brighton Posts: 84    | Going on some other threads that I've read on the d3 forum it sounds like the alternator? Id get that and the battery tested to rule them out. RRS Autobiography SDV6 19
|  Sat Jun 24 2017 7:42am |
| squizzel Member Since: 13 Jun 2013 Location: wednesbury Posts: 193      |
 There was no smell off mine, the car just cut out. Everything went dead, no lights, no advanced warning nothing. It was the alternator and it took a new battery out with it. We put a jump starter on it to get it running and drive it onto the recovery truck, and it completely flattened that in 3 minutes. | ||
|  Sat Jun 24 2017 7:58am |
| Terrye Member Since: 20 Jun 2017 Location: Wales Posts: 9      | Check your battery are clean and tight.
|  Sat Jun 24 2017 10:35am |
| Stuart Member Since: 17 Oct 2013 Location: Manchester Posts: 581      | So I charged it overnight, it started fine with no warning lights.
|  Sat Jun 24 2017 3:40pm |
| geoffsnook Member Since: 19 Nov 2016 Location: cardiff Posts: 1702      | I would say so  | ||
|  Sat Jun 24 2017 3:49pm |
| Stuart Member Since: 17 Oct 2013 Location: Manchester Posts: 581      | Ordered one, so we'll see. I expect that'll fix it. Get a 2005-2009 RRS (FAH500210) sat nav/dash mat here - the one that wasn't there when you bought the car.
|  Sat Jun 24 2017 4:25pm |
| Stuart Member Since: 17 Oct 2013 Location: Manchester Posts: 581      | So the alternator seems to have fixed it, but I have a question.
|  Fri Jun 30 2017 3:54pm |
| geoffsnook Member Since: 19 Nov 2016 Location: cardiff Posts: 1702      | Try a hard reset first to see if that cures it   | ||
|  Fri Jun 30 2017 4:33pm |
| Stuart Member Since: 17 Oct 2013 Location: Manchester Posts: 581      | Did a hard reset this morning and it was a little better, but on driving I decided that the turbo wasnt kicking in.
|  Sat Jul 01 2017 3:29pm |
| Johnski Member Since: 02 Sep 2015 Location: North Wales & North Yorkshire Posts: 1407      | I hate service garages that don't check your car is all working after repairs.   | ||
|  Sat Jul 01 2017 7:42pm |
| Posting Rules
 if the alternator is knackered it may well have taken the battery out as well .You need to see what power it is putting out when the car is running  with everything inside turned off and then with everything turned on
