Home > Maintenance & Modifications > Oil leak passenger side rear. Could it be the sway bar???
CANROVER
Canada 2010 Range Rover Sport Supercharged Santorini Black
Morning lads,
I come seeking wisdom and guidance.... And a hope that this won't cost me a kidney. My wife noticed a small fresh oil stain in the garage and it seems to be coming from the passenger side near the back of the Rangie. I had a look underneath and it seems to concentrate around this thick rubber looking bushing. Anyone know what this could possibly be?
Cheers from Canada Smile
Post #523699 Sat Apr 15 2017 1:59pm
scousefly
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
Is this on a Dynamic?
If it is could it be the rear ACE??
Post #523703 Sat Apr 15 2017 4:25pm
CANROVER
Please God nooooooooo. 😭
I heard how pricey those things are
Post #523705 Sat Apr 15 2017 4:55pm
Camelrock
+1 for leaking rear arb, mines been leaking for about 2 years now, keep thinking its time I got around to changing it Big Cry 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
2018 Discovery 5 HSE lux current
1994 Dakar current
Post #523708 Sat Apr 15 2017 5:47pm
CANROVER
Well boys,
After weighing all my *current* options, I took a trip to Canadian Tire and got me some Lucas Power Steering Stop Leak (yeah I know, my car's gonna explode lol) to see if this helps just long enough to budget for a rear sway bar replacement unless the actuator itself can be saved in some way. As for the fluid, I bought some power steering fluid marked OEM. It's not the recommended brand but it is designed for Jaguars (according to the label). I'm willing to endure the flaming I'll get here while we schedule the repair.
Hopefully the leak will stop and I can make a trip to the dealership and pick up some fluid on Monday. Haven't used that Cheapie fluid YET, but we'll see what telltale spots show up under the car in the next 24 hours.... Also getting a WD40 smelling odour coming from the vents. DOES THE FUN EVER STOP????
Censored
Post #523729 Sat Apr 15 2017 6:52pm
TheWojtek
It's a Land Rover, fun is essential brand value Smile
I would oppose putting this stop leak stuff in the system, since the ACE consists of very tight pipes and a delicate valve block with a filter. If the pump gets clogged with the stop-leak thingy or the tight passages in the valve block are blocked, you're a very unhappy man. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #523732 Sat Apr 15 2017 7:26pm
CANROVER
Just checked the fluid level and now that the engine is cooler it has gone down. I put it in dynamic mode and took it out for an aggressive 2 minute run, all is well, not getting the Vehicle lean when cornering error so for now it's OK.
Like many women, she may change her mind later.
Wojtek would you know how fast the fluid fows through the system? I put the fluid in at Canadian tire and drove home, about 5 mins and then the 2 minute run in dynamic mode. Would this be enough to circulate the solution through the system?
Post #523740 Sat Apr 15 2017 8:10pm
The Dynamic Response pump runs at 6.5L/min at idle, 10L/min at/above 1000rpm. The system has 2.5L of oil in it. 2012 SDV6 - it's missing a couple of cylinders
Post #523742 Sat Apr 15 2017 10:00pm
CANROVER
Well it looks like I've been schooled lol. Excellent reply thanks.
Post #523745 Sat Apr 15 2017 11:03pm
scousefly
Do you
Have a warranty? Mine has just been replaced at Ł1952 under Land Rover warranty. Came up as an advisory on the MOT
Post #523791 Sun Apr 16 2017 1:35pm
CANROVER
If I had a warranty I would not be putting stop leak in the system... Rolling with laughter
Seriously though, my warranty expired feb 2016 but the service manager and I milked that sucker till the very end. Even two days prior the the date of expiry I managed to get a new windshield out of it. All things considered I'm pretty sure I racked up well over 30,000 CDN in warranty repairs. I'm not complaining at all. Great service and they covered EVERY LITTLE THING except for the battery. 10 out of 10 in my books. I've heard the horror stories about some of the LR dealerships out there and I'm glad our local LR treats their clients this well.
Post #523808 Sun Apr 16 2017 6:11pm
