![]() | Home > Technical > Long travel on brake pedal |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2015 ![]() ![]() |
Simple one: call LR Assist and they will come out to you and inspect it. You've paid for it as part of the deal.
Have you checked level in master cylinder reservoir? * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
Smarttech Member Since: 11 Jan 2017 Location: West Sussex Posts: 426 ![]() ![]() |
Not checked it yet but will have a look in the morning. 2019 4.4 SDV8 Autobiography Velocity blue.
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1557 ![]() ![]() ![]() |
No car should have that problem with the brakes. Definitely a fault. And dangerous. Sounds like a rubber seal has gone somewhere.
It's had quit a bit of travel on the brakes ever since I picked the car up but the brakes work ok so just thought that's how they are but my dad drove it and said he didn't think he was going to stop the first time he hit the pedal as it dropped so far before the brakes worked
Call LR Assist. It's part of your Approved Used Warranty. If they deem it dangerous then it will be recovered to dealer and made a priority. You will be given a loan car. They will want that loan car back ASAP so they prioritise the work on yours.
Its not so much the long travel (although that's still a bit of a problem) - more concerning IMHO is the fade when you keep pressure on the brake peddle. Shouldn't happen. Robin
Will give them a call this morning. Just didn't want to make a fuss about it to find theirs nothing wrong with it and they are all like that.
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 ![]() |
Ridiculous.
Totally supports Wilf's view here - and the dealer should take it off the road straight away and provide a courtesy car for you in the meantime. If they can't do it for a month then that's their problem not yours. Trading Standards springs to mind if you don't get an immediate favourable response Robin
Land Rover assistance are coming out today to look at it. They offered the AA in under 90 mins but thought I would wait for the Land Rover tech as they should know more about it that the AA.
LR Assist would not let me drive mine when I reported a leaky front brake hose as it was deemed unsafe. * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
LR Assist have been out and confirmed the brakes work ok but we're concerned about the amount of travel on the pedal before they start to do anything so it's now on its way to the dealer with my dad to pick up a courtesy car.
My money is on a new master cylinder/servo assembly............ MY2016 HSE D SDV6 - gone due to fuel dilution problems.
