Home > Technical > Long travel on brake pedal
Smarttech
I have a 2012 RRS sdv6 which I bought from the main dealer 2 months ago which is fantastic apart from having a lot of travel on the brake pedal before they start to do anything. If I press the pedal then release and re press then it's firm from the top as I would expect it to be.
Tonight I started the car and pumped the brakes till firm but if you hold the pressure on the pedal drops nearly to the floor.
Is this normal in the sport or should the pedal be firm when you hit the brakes ?
Spoke to the dealer today and explained the issue to be told they can't book it in to look at it till 24/04/17. 2019 4.4 SDV8 Autobiography Velocity blue.
2017 SVR. SVO Scafell grey Ebony interior. Gone
2012 3.0 SDV6 Autobiography santorini black with ebony/cirrus interior. Gone
Post #522186 Tue Mar 28 2017 9:08pm
DrRob
Simple one: call LR Assist and they will come out to you and inspect it. You've paid for it as part of the deal.
Thumbs Up * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
I use www.glenrands.co.uk Great independent
Post #522187 Tue Mar 28 2017 9:16pm
DrRob
Have you checked level in master cylinder reservoir? * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
Post #522188 Tue Mar 28 2017 9:17pm
Smarttech
Not checked it yet but will have a look in the morning. 2019 4.4 SDV8 Autobiography Velocity blue.
Post #522190 Tue Mar 28 2017 9:21pm
Eaters
No car should have that problem with the brakes. Definitely a fault. And dangerous. Sounds like a rubber seal has gone somewhere.
Absolutely get it looked at. Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #522205 Tue Mar 28 2017 11:43pm
Smarttech
It's had quit a bit of travel on the brakes ever since I picked the car up but the brakes work ok so just thought that's how they are but my dad drove it and said he didn't think he was going to stop the first time he hit the pedal as it dropped so far before the brakes worked
I test drove 3 cars before buying this one but can't remember if they were all like it to know if they all have a long pedal. 2019 4.4 SDV8 Autobiography Velocity blue.
Post #522209 Wed Mar 29 2017 7:03am
DrRob
Call LR Assist. It's part of your Approved Used Warranty. If they deem it dangerous then it will be recovered to dealer and made a priority. You will be given a loan car. They will want that loan car back ASAP so they prioritise the work on yours.
0800 521 786
Whistle * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
Post #522210 Wed Mar 29 2017 7:24am
Eaters
Its not so much the long travel (although that's still a bit of a problem) - more concerning IMHO is the fade when you keep pressure on the brake peddle. Shouldn't happen. Robin
Gone:
MGZTT 190 2.5
Post #522211 Wed Mar 29 2017 7:31am
Smarttech
Will give them a call this morning. Just didn't want to make a fuss about it to find theirs nothing wrong with it and they are all like that.
Thought the dealer would of said to pop by so they can get a tech to try it but just got told they can't look for a month. 2019 4.4 SDV8 Autobiography Velocity blue.
Post #522212 Wed Mar 29 2017 7:36am
wilf
Ridiculous.
That is a safety critical situation and the Dealer should have been over it like a rash.
Tell LR Assist you are really (REALLY) worried about the brakes failing completely, that should speed things up. And if the pedal does sink to the floor, they will, and not at a time you choose. You and your family are at risk here, get annoyed about it! MY2016 HSE D SDV6 - gone due to fuel dilution problems.
By the age of 50 you have the face you deserve - George Orwell.
Post #522216 Wed Mar 29 2017 7:57am
Eaters
Totally supports Wilf's view here - and the dealer should take it off the road straight away and provide a courtesy car for you in the meantime. If they can't do it for a month then that's their problem not yours. Trading Standards springs to mind if you don't get an immediate favourable response Robin
Gone:
MGZTT 190 2.5
Post #522217 Wed Mar 29 2017 8:02am
Smarttech
Land Rover assistance are coming out today to look at it. They offered the AA in under 90 mins but thought I would wait for the Land Rover tech as they should know more about it that the AA.
Will let you know the outcome later once they have been out to it. 2019 4.4 SDV8 Autobiography Velocity blue.
Post #522229 Wed Mar 29 2017 10:29am
DrRob
LR Assist would not let me drive mine when I reported a leaky front brake hose as it was deemed unsafe. * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
Post #522235 Wed Mar 29 2017 12:04pm
Smarttech
LR Assist have been out and confirmed the brakes work ok but we're concerned about the amount of travel on the pedal before they start to do anything so it's now on its way to the dealer with my dad to pick up a courtesy car.
Will wait for a report back on what they find. 2019 4.4 SDV8 Autobiography Velocity blue.
Post #522245 Wed Mar 29 2017 2:47pm
wilf
My money is on a new master cylinder/servo assembly............ MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Post #522246 Wed Mar 29 2017 3:47pm
