Home > General > Spotlights for road trip
Salisburylander
2011 Range Rover Sport 3.0 TDV6 HSE Bali Blue
Has anyone put extra spotlights on their RRS? I'm only asking cos I've been invited to a wedding in Northern Sweden and it was recommended to have them so that deer, reindeer and moose could be seen more readily at night. Apparently, they are quite a hazard in the North. Hopefully, bit of a road trip next month.
Post #520820 Mon Mar 13 2017 10:58pm
Tyrefitter
You need the led's like I have on my truck,,a 392watt on the nudgebar & a 572 on the rollbar.
Andy Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #520823 Mon Mar 13 2017 11:17pm
Socast
I've not fitted spot lights but I have got these fitted as replacement high beams:
https://www.amazon.co.uk/gp/product/B01I4Y...&psc=1
I've had them fitted for a little while now and can highly recomend them! They have a wider spread than the stock halogens (as the light doesn't hit the reflectors the same way) and illuminate a much wider area, you do lose a bit of your overall view distance, but it's not a lot, imho they're FAR superiour to stock bulbs.
After I fitted them I've not had to touch them again.
I've just bought a set of these yesterday:
http://www.ebay.co.uk/itm/291960623515?_tr...EBIDX%3AIT
Now I've not recieved them yet, so I can't say if they're better or reliable. On paper they should be far superior and just as reliable, but obviously heading on a long road trip you need reliability as much as you need power.
For reference, the stock 55w Halogen bulb emits a maximum of 1800 lumens, The kit from Amazon emits 3600 lumens per bulb and the set I've just purchased emits 10,000 lumens per bulb.
While technically these kits are illegal for road use, as they're used in the high beam they're legal (you don't have high beams on when approaching oncoming traffic). To confirm; I had them fitted when I went for MOT and didn't have any issues.
You'll need a set of these to hold either set of bulbs in place:
http://www.ebay.co.uk/itm/2x-H7-HID-Xenon-...SwNRdX5Iiu
You won't need to modify anything to fit the bulbs, but it is a bit of a fiddle. I found I had to slacken the two torx retaining screws a little, fit the bulbs and then re-tighten them again.
If deer are that big of an issue though it might be worth looking into fitting a bullbar and mounting a couple of spotlights in the same fashion as Tyrefitter.
Post #520836 Tue Mar 14 2017 10:08am
Pufftmw
I've just fitted the RRS Driving/Fog Light kit VUB502440 to my car & whilst the look is not everyone's cup of tea maybe, first impressions of the lights are good. Much more "throw"/range and a higher beam too. Admittedly this was in a long darkish street in London but they illuminated the house at the end when on but not when off.
I've got some H11 LEDs on their way to me, so will upgrade the driving light bulbs with them. I'll wait until I get to Wales tomorrow (where it is very dark!) and try and do a comparison - DL off, standard bulbs on, LEDs on
Post #520970 Wed Mar 15 2017 10:03am
Bodsy
Site Sponsor
I've got a set of those driving/fogs complete unused for sale if you're interested, let me know. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #520971 Wed Mar 15 2017 10:36am
Bodsy
Site Sponsor
Not sure that they'd fit your 2011 bumper though. Bodsys Brake Bible
See it HERE
Post #520973 Wed Mar 15 2017 10:37am
Socast
What're you asking for them and do you have all the instructions, templates etc. ?
Post #520988 Wed Mar 15 2017 11:34am
Lost for Words
I thought the driving lamps took H9 bulbs? They are very high efficacy (2100lm) so I would stongly recommend sticking with them (if they are H11 though, H9s can be retrofitted by trimming the tabs).
Driving lamps really require a tight focus to get the best out of them which LEDs would spoil - the key to seeing further is to get more light down the road without adding it in the foreground. An LED retrofit disperses the light nearby, meaning you do not see further and often see less far, and often the dispersion is enough to mean lower outright intensity too.
Thumbs Up Visiting from DISCO3.CO.UK
Post #520991 Wed Mar 15 2017 11:54am
Pufftmw
Thank you!
They do take H9s but all the LED kits are H8,H9,H11 multifit, so my bad at remembering, sorry Embarassed
I shall do the test and find out Smile
Post #520992 Wed Mar 15 2017 12:00pm
Lost for Words
Bear in mind, the higher colour temperature of the LEDs will trick your eyes, making it seem brighter, and as long as you have a decent level of light, the balance of light between near and far is more important than the brightness - i.e. quality over quantity. Thumbs Up Visiting from DISCO3.CO.UK
Post #520997 Wed Mar 15 2017 12:42pm
As an aside, how easy are they to fit? I've got a set in my garage that I'm slightly scared of - the fitting of them that is. The instructions suggest a somewhat involved installation... Embarassed 2012 SDV6 - it's missing a couple of cylinders
Post #521014 Wed Mar 15 2017 6:30pm
Bodsy
Site Sponsor
It's a bit time consuming and of course you need to cut the bumper, but with the included templates, it's not too bad to do. Take the bumper off of course and you'll need to lift the engine bay fusebox (from memory) but that's dead easy.
Brave pill only really needed to cut the hole for the lights switch near the steering wheel, but even if you mess that up, the switch plate will cover it up (again. Going from memory) Bodsys Brake Bible
See it HERE
Post #521057 Wed Mar 15 2017 11:40pm
delta351
How about RRS fogs and spot lights.
http://www.ebay.co.uk/itm/Genuine-Range-Ro...Swax5YyU7W
 2006 RR Sport Supercharged Love this car
2009 BMW 335D GONE
2008 VW R32 GONE
1999 RR SE GONE
1994 RR HSE GONE
2001 VW V5 GONE
Post #521060 Thu Mar 16 2017 12:08am
garrycol
Australia
Hitting wildlife at night is a constant issue here - especially in the suburbs of Canberra.
The main issue is the animals on the side of the road just outside your light beams which suddenly walk in front of your car and for this you need wide beams with light up the roadside.
My suggestion for seeing the road way ahead is a set of HID driving or spotlights with a curved or multifunction LED light bar in between them. The spots will give distance and the LED light bar, either curved or ones that have the ends angled to the side will light up the sides of the road.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #521061 Thu Mar 16 2017 2:15am
Socast
I received the 10k lumen bulbs tonight, I fitted one and went for a drive. I've got mixed emotions if I'm honest, the new bulbs are nowhere near the claimed 10k, BUT, they're no dimmer than the 3600k bulbs I already have and as a final cherry on top they even focus better and give a more obvious focal point.
Video is here:
So to summarise, better than my previous bulbs but not as bright as claimed.
Post #521122 Thu Mar 16 2017 10:14pm
