Home > Maintenance & Modifications > 2005 sc engine oil change question
steve.rrs
hi, i need to change the engine oil on my 2005 4.2 sc engine, there seems to be 2 ways to change the oil, either drain oil from sump plug or get a vac pump and pump it out from the top, which method is better?
Post #518186 Sun Feb 19 2017 8:11am
Tim in Scotland
I'm no mechanic but I was always told to drain oil through the sump. You get all the particles that may be on the magnetic sump plug out and you can leave it overnight to drip out as much old oil as possible. Vacuum pumps are for service bays where time is money............... and they don't get all the crap out from the sump. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #518188 Sun Feb 19 2017 8:19am
steve.rrs
thanks tim
Post #518202 Sun Feb 19 2017 10:26am
Socast
Don't cut corners and buy cheap oil.
I've been told that the book time to change the timing chains is around 30 hours, the chains and tensioners come in at £500+ on their own. Whistle
Post #518339 Mon Feb 20 2017 12:40pm
Tyrefitter
As Tim says,,drain from sump plug & probably worth putting a flush through it aswell then leave a couple of hours before putting sump plug back in & use the proper oil NOT the cheap S@@@e from local motor factors.
Andy Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #518342 Mon Feb 20 2017 12:52pm
shouldn't need a flush on a petrol.
Post #518345 Mon Feb 20 2017 1:09pm
steve.rrs
what oil does everyone recommend
Post #518535 Tue Feb 21 2017 11:32pm
Socast
I use Fuchs Titan Race Pro, it's an over spec'ed race grade oil so better than the Castrol oil that is recommended by JLR
Post #518558 Wed Feb 22 2017 9:44am
steve.rrs
thanks socast, i was planning on changing the engine oil every 10,000 miles and the oil filter every other oil change, does this sound about right
Post #518758 Thu Feb 23 2017 10:22pm
Socast
It depends on the oil you use and how you drive. If you drive gently and use synthetic oil then 10k miles is ok. I personally change my oil annually as I don't do that many miles.
As for the filter it's common practice to relace the oil filter at every service. An oil filter costs £15, a reconditioned engine is £8k, I'll leave it to you to decide which you would rather change haha.
Cabin, pollen filters I tend to change when they need doing, my current cabin and pollen filters are 3 years old.
As I don't do many miles I change the air filter bi-annually. But again this depends on your driving and enviroment, it is usually recommended you change the air filter at every service.
Post #518786 Fri Feb 24 2017 10:06am
sonnyjim
United Kingdom 2006 Range Rover Sport Supercharged Cairns Blue
I use the standard Titan fuchs... Thumbs Up '06 RRS Supercharged Cairns Blue
Post #519163 Mon Feb 27 2017 3:54pm
Socast
With my car about to roll over to 100k miles, I'm mulling over whether to switch to Millers 10w40 oil:
http://www.opieoils.co.uk/p-115229-millers...-2017.aspx
Post #519167 Mon Feb 27 2017 4:08pm
0w-40 is the wrong spec isn't it? 5W30 normally.
Oil brand is a very subjective thing.
Unless it does something really bad oils don't tend to stand out.
I don't like paying more than £20 per 5 litres (fully synthetic 5W30) and you can get it for less if you buy 4 bottles worth.
I run AC Delco in my Jag S/C. I like to get it for ~£17 for 5l when you purchase 4. That's about the same as trade price.
Post #519196 Mon Feb 27 2017 8:04pm
Socast
Sorry made a typo, Should have been 10w40
It's different to required spec yes, but the increased viscosity should offset against engine wear, meaning less future wear. There may well be a drop in MPG and horse power due to increased rotational resistance but then you've got the choice between power or life. The light that burns twice as bright burns half as long!
The difference between the two oil's is marginal but based on the numbers I can't see how it can have a negative effect on the engine.
That being said I'm still mulling it over, I may try it and see how the engine sounds/performs and make the decision based on that.
Post #519270 Tue Feb 28 2017 10:29am
Link also wrong
A good quality synthetic oil should be all that is required to ensure long engine life, (as well as frequent changes).
I vaguely remember my Jag S/C manual states 5W40 can be used (and it's selection is dependent on ambient temperature range)
Considering the RRS manual only states 5W30 I don't know why on earth you would want to go against this or what benefit you would gain.
Post #519312 Tue Feb 28 2017 1:15pm
