![]() | Home > Maintenance & Modifications > 2005 sc engine oil change question |
I'm no mechanic but I was always told to drain oil through the sump. You get all the particles that may be on the magnetic sump plug out and you can leave it overnight to drip out as much old oil as possible. Vacuum pumps are for service bays where time is money............... and they don't get all the crap out from the sump. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
| steve.rrs Member Since: 27 Aug 2014 Location: devon Posts: 90
thanks tim |
| Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594
Don't cut corners and buy cheap oil.
| Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3677
As Tim says,,drain from sump plug & probably worth putting a flush through it aswell then leave a couple of hours before putting sump plug back in & use the proper oil NOT the cheap S@@@e from local motor factors.
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5147
shouldn't need a flush on a petrol. |
what oil does everyone recommend |
I use Fuchs Titan Race Pro, it's an over spec'ed race grade oil so better than the Castrol oil that is recommended by JLR |
thanks socast, i was planning on changing the engine oil every 10,000 miles and the oil filter every other oil change, does this sound about right |
It depends on the oil you use and how you drive. If you drive gently and use synthetic oil then 10k miles is ok. I personally change my oil annually as I don't do that many miles. As for the filter it's common practice to relace the oil filter at every service. An oil filter costs £15, a reconditioned engine is £8k, I'll leave it to you to decide which you would rather change haha. Cabin, pollen filters I tend to change when they need doing, my current cabin and pollen filters are 3 years old. As I don't do many miles I change the air filter bi-annually. But again this depends on your driving and enviroment, it is usually recommended you change the air filter at every service. |
| sonnyjim Member Since: 22 Jun 2013 Location: Kent Posts: 131
I use the standard Titan fuchs... |
With my car about to roll over to 100k miles, I'm mulling over whether to switch to Millers 10w40 oil:
0w-40 is the wrong spec isn't it? 5W30 normally.
Sorry made a typo, Should have been 10w40 It's different to required spec yes, but the increased viscosity should offset against engine wear, meaning less future wear. There may well be a drop in MPG and horse power due to increased rotational resistance but then you've got the choice between power or life. The light that burns twice as bright burns half as long! The difference between the two oil's is marginal but based on the numbers I can't see how it can have a negative effect on the engine. That being said I'm still mulling it over, I may try it and see how the engine sounds/performs and make the decision based on that. |
Link also wrong
| All times are GMT |
