![]() | Home > Maintenance & Modifications > battery problems?? |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5134 ![]() ![]() ![]() |
I would have thought you would have other dash error messages when you start the engine if the battery was low. These are usually the first signs. |
Wayneclarke Member Since: 16 Jun 2014 Location: kent Posts: 394 ![]() ![]() ![]() |
yeah i replaced the battery in 2015 because of these problems so i replaced it then my alternator fried so i think maybe the battery took a bit of a whack, the navigation reboots at the moment but no other signs but the FBH locking out i think is due to low voltage |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796 ![]() ![]() |
I Had the same kind of issue - booked it in for the FBH to be checked under warranty - the battery was the issue & I had no other error codes at all on the dash. I did trickle charge the battery using my CTek but even that didn't give the charge needed for the FBH. |
yeah snap mate i use a ctek charger at least once a month due to short journeys, but it doesn't seem to be working i think the alternator has killed it a little bit, What battery did you replace it with ??? I'm looking at this one http://www.eurocarparts.com/ecp/p/car-batt...mp;cc5_999 |
I let the dealership put it on - I just handed over my hard earned cash |
ha ha lucky man |
Wasn't that lucky - a few weeks later I part exchanged it in for my current Sport - it was an impulse thing - Mrs hasn't let me forget it |
donny dog Member Since: 23 Nov 2016 Location: yorkshire Posts: 772 ![]() ![]() |
Pardon my ignorance, but what is an 'FBH'? |
fuel burning heater |
Aaaaaah.....thanks!! |
well quick update i went and bought a new battery |
I haven't had the FBH unlocked yet but will soon find out once I have done if it locks out again |
Never knew it locked out - how does that happen ? 16MY Estoril Blue SVR.............
