![]() | Home > Technical > headgasket................ |
Orange RRS Member Since: 24 May 2016 Location: Lincolnshire Posts: 89 ![]() ![]() ![]() |
I've seen a lot of high mileage tdv6's and can't say headgaskets are a common fault. Have you got combustion pressure in the water system. Check that you have got water circulating through the cooling system and no air locks.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4513 ![]() ![]() ![]() |
No, but I have heard of a few cracked blocks... |
nosmokenopoke Member Since: 09 Jul 2016 Location: Gloucestershire South West Posts: 44 ![]() ![]() ![]() |
Hi mate, Tbh i hate them too. As soon as this is fixed i'm going to buy the newer super charged or a R8. I've spent a fortune on this already. I have water coming out the exhaust pipes at rear and its now created a misfire on a cylinder. I am going to pressure test the cylinders 1 by 1 to see which head is at fault then i will update you all. thanks jon |
Hi Mikey, Well i got to be honest with you if the block is cracked then its all going on ebay. I am not rebuilding another tdv6 thats a fact Thanks Mate Jon |
