Home > Technical > headgasket................ |
Orange RRS Member Since: 24 May 2016 Location: Lincolnshire Posts: 89 |
I've seen a lot of high mileage tdv6's and can't say headgaskets are a common fault. Have you got combustion pressure in the water system. Check that you have got water circulating through the cooling system and no air locks.
Tue Nov 01 2016 11:29pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4345 |
No, but I have heard of a few cracked blocks... |
Wed Nov 02 2016 7:56am |
nosmokenopoke Member Since: 09 Jul 2016 Location: Gloucestershire South West Posts: 44 |
Hi mate, Tbh i hate them too. As soon as this is fixed i'm going to buy the newer super charged or a R8. I've spent a fortune on this already. I have water coming out the exhaust pipes at rear and its now created a misfire on a cylinder. I am going to pressure test the cylinders 1 by 1 to see which head is at fault then i will update you all. thanks jon |
Fri Nov 04 2016 1:55pm |
Hi Mikey, Well i got to be honest with you if the block is cracked then its all going on ebay. I am not rebuilding another tdv6 thats a fact Thanks Mate Jon |
Fri Nov 04 2016 1:56pm |
