![]() | Home > Maintenance & Modifications > Heated seat issue |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5062 ![]() ![]() ![]() |
There is a white 25a fuse under the bonnet for them. |
German-wheels Member Since: 23 Jul 2016 Location: Bournemouth Posts: 88 ![]() ![]() ![]() |
Thanks Andy k,
Thehos Member Since: 24 Jul 2016 Location: Somerset Posts: 123 ![]() ![]() |
I got an issue with mine, rear near side don't work |
Found the plug to connect them to, it's a box with aford logo on it.
failed element possibly |
Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278 ![]() ![]() |
Not sure if they work unless seat belts are fastened, but I may be way off with that. Could just be coincidence that I don't feel them warming up until I've buckled up. |
Jaggs Member Since: 09 Aug 2015 Location: Leeds Posts: 259 ![]() ![]() ![]() |
Mine work without seatbelt did have to replace drivers side base element, put a new foam in at same time, which made the seat much more comfy. Element and foam were £95 for both took about an hour to fit . Nanocom Evo |
Probably just me then. To be fair I only switch mine on once I've put my belt on. I have tried to switch the passenger seat on for my wife before she gets in (who says chivalry is dead?) but it doesn't warm up quick enough for me to check.
If no one is sitting in my front passenger seat, normally wife, the seat will not heat till she is in and buckles up.
I tried it and the passenger seat does heat up without the seatbelt being fastened. I'm in the shed, I'll be back in the real world in a minute.
andywatson Member Since: 03 Jan 2016 Location: Colchester Posts: 69 ![]() ![]() ![]() |
Just had this issue, rears were working - new control module was needed ![]() 2010 RRS 3.0 HSE - Nara Bronze / Almond - Gone 2009 RRS 3.0 SE - Sliver / Teal |
icross15 Member Since: 04 Dec 2016 Location: Bromsgrove Posts: 4 ![]() ![]() ![]() |
Hi Jaggs, looks like I am going to have to do this also. Do you have any tips or things to watch out for when doing this? Did you do it with the seat still fixed in the car? Thanks Ian |
I followed this post by Slim444 was a doddle really even used the original big rings just opened them out with a pair of long nose pliers
