Home > Maintenance & Modifications > Heated seat issue
German-wheels
Heated seat issue
Hi all,
Tried my heated seats for the first time and they don't work! Seems to be both front that don't work, haven't tried the rear seat yet so unsure if that works.
The 2 lights illuminate and then go to one light so they seem to be working.
Could this be a fuse, if so does anyone know it's location?
Thanks Daryl
Post #508958 Sun Oct 30 2016 7:30pm
There is a white 25a fuse under the bonnet for them.
Post #508959 Sun Oct 30 2016 7:45pm
German-wheels
Thanks Andy k,
Checked it and all is fine with the fuse, tried the rear heated seats and they are working fine!
Decided to look under the front seats and there is a plug loose on both of them a black 4 pin plug with some red inside.
Couldn't see any location for it to plug into, but there is enough wiring under the seats to stretch to the moon! Does anyone know the rough location of the plug that comes from the car? (The but I can see on both seats goes into the seat base and back)
Thanks again
Post #508966 Sun Oct 30 2016 8:15pm
Thehos
I got an issue with mine, rear near side don't work
Post #508968 Sun Oct 30 2016 8:20pm
German-wheels
Found the plug to connect them to, it's a box with aford logo on it.
Plugged them in on both front seats, passenger heats up well, nothing from driver side though.
So...... what could be causing the driver side heater to not work!
Post #508977 Sun Oct 30 2016 8:59pm
failed element possibly
Post #508978 Sun Oct 30 2016 9:13pm
Russben
Not sure if they work unless seat belts are fastened, but I may be way off with that. Could just be coincidence that I don't feel them warming up until I've buckled up. Confused I'm in the shed, I'll be back in the real world in a minute.
Gone- 2010 TDV6; Hello 2017 SDV6.
Post #509080 Tue Nov 01 2016 12:43pm
Jaggs
Mine work without seatbelt did have to replace drivers side base element, put a new foam in at same time, which made the seat much more comfy. Element and foam were £95 for both took about an hour to fit . Nanocom Evo
Post #509082 Tue Nov 01 2016 1:08pm
Russben
Probably just me then. To be fair I only switch mine on once I've put my belt on. I have tried to switch the passenger seat on for my wife before she gets in (who says chivalry is dead?) but it doesn't warm up quick enough for me to check.
Might have to try it now just for personal inquisitiveness. I'm in the shed, I'll be back in the real world in a minute.
Post #509084 Tue Nov 01 2016 1:38pm
Johnski
If no one is sitting in my front passenger seat, normally wife, the seat will not heat till she is in and buckles up.
Not sure if it's seat belt, seat weight both that it senses, but worked fine on all settings when occupied but doesn't if not in use. I thought it was normal featurel, but now thinking possibly not. Question MY2012 SDV6 HSE Lux. John
Post #509130 Wed Nov 02 2016 12:56am
Russben
I tried it and the passenger seat does heat up without the seatbelt being fastened. I'm in the shed, I'll be back in the real world in a minute.
Post #509250 Thu Nov 03 2016 7:27pm
andywatson
United Kingdom 2008 Range Rover Sport TDV8 HST Stornoway Grey
Re: Heated seat issue
German-wheels wrote:
Hi all,
Thanks Daryl
Just had this issue, rears were working - new control module was needed Thumbs Up 2008 RRS 3.6 HST - Stornaway / Black - Current
2010 RRS 3.0 HSE - Nara Bronze / Almond - Gone
2009 RRS 3.0 SE - Sliver / Teal
Post #509354 Fri Nov 04 2016 11:13pm
icross15
United Kingdom 2006 Range Rover Sport TDV6 Autobiography Java Black
Hi Jaggs, looks like I am going to have to do this also. Do you have any tips or things to watch out for when doing this? Did you do it with the seat still fixed in the car?
Thanks
Ian
Post #511499 Sun Dec 04 2016 11:59am
Jaggs
I followed this post by Slim444 was a doddle really even used the original big rings just opened them out with a pair of long nose pliers
http://www.rrsport.co.uk/forum/topic43630.html Nanocom Evo
Post #511525 Sun Dec 04 2016 4:35pm
