![]() | Home > Maintenance & Modifications > Any ideas on what the mystery wire is???? |
M12UPY Member Since: 03 Dec 2015 Location: Manchester Posts: 81 ![]() ![]() ![]() |
Ok so I better not pull it then |
Danv8 Member Since: 20 Apr 2015 Location: Norfolk Posts: 378 ![]() ![]() ![]() |
It's not an emergancy pull, it is the locking cable for the fuel filler cap. Next time you lock your car see if you can open the cap. Bet it will open as normal.
So should it be attached somewhere ? |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5126 ![]() ![]() ![]() |
1. Lock and unlock car and see if the black end moves correctly. Otherwise no point trying to home it
Don't get what your saying regarding back moving around |
Plazmapete Member Since: 05 Jun 2016 Location: Cannock Posts: 118 ![]() ![]() ![]() |
When you lock the car the black plastic rod should move out and in when you unlock it. Mine was broken and had to drill and tap it and fit a short length of 3mm all thread. Works fine now. |
Ah ok think mine is broke as it dosnt move |
Hence when someone wanted to fuel the car they ripped that bit out so the flap would open |
So I pushed it back into the nearest hole behind the flap and it clipped in nicely and guess what it flipping works |
My guess is at some point it's had a sticking actuator so when unlocking it didn't release the fuel flap, or they didn't double unlock so again it didn't unlock it, so they yanked it out to get access to fill up with fuel and left it. Mine stuck I yanked on it and it broke the end off it. |
