Home > Maintenance & Modifications > Any ideas on what the mystery wire is????
M12UPY
England 2009 Range Rover Sport TDV6 HSE Lux Stornoway Grey
Found this in the side of the boot looks like a bike brake cable Shocked
Post #502925 Mon Aug 15 2016 8:58pm
Emergency fuel filler flap release. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #502927 Mon Aug 15 2016 9:01pm
M12UPY
Ok so I better not pull it then Laughing
Post #502928 Mon Aug 15 2016 9:26pm
Danv8
United Kingdom 2009 Range Rover Sport TDV6 HSE Lux Alaska White
It's not an emergancy pull, it is the locking cable for the fuel filler cap. Next time you lock your car see if you can open the cap. Bet it will open as normal.
http://www.rrsport.co.uk/forum/topic44719.html
Post #502929 Mon Aug 15 2016 9:56pm
M12UPY
So should it be attached somewhere ?
Post #502931 Mon Aug 15 2016 10:19pm
1. Lock and unlock car and see if the black end moves correctly. Otherwise no point trying to home it
2. It's meant to be pushed into a black plastic surround, but chances are it won't be an easy job as a spacer will have fallen down in the wheel arch area and lost
Post #502948 Tue Aug 16 2016 12:03pm
M12UPY
Don't get what your saying regarding back moving around
Post #502986 Tue Aug 16 2016 7:05pm
Plazmapete
When you lock the car the black plastic rod should move out and in when you unlock it. Mine was broken and had to drill and tap it and fit a short length of 3mm all thread. Works fine now.
Post #502989 Tue Aug 16 2016 7:50pm
M12UPY
Ah ok think mine is broke as it dosnt move
Post #502990 Tue Aug 16 2016 7:53pm
Hence when someone wanted to fuel the car they ripped that bit out so the flap would open
Post #502992 Tue Aug 16 2016 8:16pm
M12UPY
So I pushed it back into the nearest hole behind the flap and it clipped in nicely and guess what it flipping works Very Happy happy days cheep guys mystery solved Thumbs Up
Post #502995 Tue Aug 16 2016 9:04pm
Danv8
My guess is at some point it's had a sticking actuator so when unlocking it didn't release the fuel flap, or they didn't double unlock so again it didn't unlock it, so they yanked it out to get access to fill up with fuel and left it. Mine stuck I yanked on it and it broke the end off it.
Post #503021 Wed Aug 17 2016 5:55am
