![]() | Home > Maintenance & Modifications > Quick question - wet passenger footwell |
Hi, yes. If the black scuttle cover doesn't fit tight to the screen water gets past and drips into the ventilation air intake. The cover is held in place with clips like those on the A pillar. Try just pushing hard to make them clip in. If that doesn't work you'll need to take it off and replace some of the clips.
Pakolainen Member Since: 14 Mar 2016 Location: Helsinki Posts: 310 ![]() ![]() ![]() |
Thanks,
If I remember correctly they are white clips with a rubber gasket so probably these:
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5139 ![]() ![]() ![]() |
Thank's Paddi, |
Thanks Gents.
