Home > Maintenance & Modifications > Quick question - wet passenger footwell
Pakolainen
Finland 2013 Range Rover Sport 3.0 TDV6 Autobiography Rimini Red
Hi.
Have read posts and written posts with great responses with regards to wet passenger footwell.
I've fixed the exterior A pillar plugs. And have checked and cleaned the sun roof drainage pipes.
But i still have a soaking wet footwell. Would the black 'plastic' cover at the bottom of the windscreen - exterior have something to do with this. Just noticed that mine doesn't sit flush to the windscreen.
I presume this isn't normal. Can it be repaired or is it replacement only?
Thanks 2019 RRS P400e Autobiography
2014 RRS 3.0 TDV6 HSE Dynamic
2006 RRS 2.7 TDV6 HSe
Alfa Romeo Guillietta 2.0 JTDM 2011
Mazda 3 1.6 2010
Subaru Impreza 2.0 WRX 2005
Post #502652 Fri Aug 12 2016 10:42am
Paddi
Hi, yes. If the black scuttle cover doesn't fit tight to the screen water gets past and drips into the ventilation air intake. The cover is held in place with clips like those on the A pillar. Try just pushing hard to make them clip in. If that doesn't work you'll need to take it off and replace some of the clips.
Hope that fixes it for you. 2008 MY Java Black TDV8 HSE
Post #502657 Fri Aug 12 2016 11:43am
Pakolainen
Thanks,
had a quick peek and seems that clips are broken. any idea on whether these on ebay or a genuine LR part.
thanks
Steve 2019 RRS P400e Autobiography
Mazda 3 1.6 2010
Post #502658 Fri Aug 12 2016 11:49am
Paddi
If I remember correctly they are white clips with a rubber gasket so probably these:
https://www.google.co.uk/search?q=land+rov...3088981882
No doubt Col will be along soon to give you the part no. He is the forum equivalent of Andrew on Test Match Special 2008 MY Java Black TDV8 HSE
Post #502678 Fri Aug 12 2016 6:01pm
Thank's Paddi, Laughing
Would you believe L/R don't list the clips for the scuttle panel separate, but I'm sure you are right they are the white one's with the seal the Part No. for these is LR013135
Steve, if you google part no. should get picture to compare with your own.
Found this one.
Post #502681 Fri Aug 12 2016 6:50pm
Paddi
Laughing never lets us down. 2008 MY Java Black TDV8 HSE
Post #502683 Fri Aug 12 2016 7:44pm
Pakolainen
Thanks Gents.
Have checked the clips and they are broken, also pressing down the scuttle panel / cowl seals the gap but it looks like it might be warped. So probably best to order a new one.
Cheers 2019 RRS P400e Autobiography
Mazda 3 1.6 2010
Post #502794 Sun Aug 14 2016 12:31pm
