![]() | Home > Technical > Power for reversing camera |
Garage Door Medic Member Since: 02 Feb 2014 Location: North West of UK Posts: 197 ![]() ![]() ![]() |
Have you not got a cigarette power socket in the boot ???? MY 13 3.0 SDV6 HSE Black Edition
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5118 ![]() ![]() ![]() |
How about reversing light then when you engage reverse it powers camera.
Plazmapete Member Since: 05 Jun 2016 Location: Cannock Posts: 118 ![]() ![]() ![]() |
Could do. I will have to run a wire from reversing light up through the rear quarter panel and then back down through the tailgate glass. Will be a pain. |
Whenever I fit them, I use a high quality cable that has power, signal and ground in the same cable. That way, one cable is required, making it a tidier install. Other end is matched to reverse signal from the fusebox for power and the signal terminated in a new phono connector. Bodsys Brake Bible
I have got a wireless one. So just need power. Thanks. |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5116 ![]() ![]() ![]() |
For reversing light feed, I would run the wire down from the roof to the passenger side, and connect to the towbar plugs in the left side of the boot.
Thanks for that. Will have a look later. |
