![]() | Home > Technical > Corroded front to rear brake pipes |
That's expensive for 2 brake pipes,we charge £40 per pipe.its only £10 for a roll of copper pipe & you would probably be able to do full car with one roll.
Jaggs Member Since: 09 Aug 2015 Location: Leeds Posts: 259 ![]() ![]() ![]() |
Is it something you can do Andy, happy to travel and wait |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5116 ![]() ![]() ![]() |
Have you done a RRS before ?
Don't really want to hide the problem, if the pipes fail its a lot of car to stop but feel sure I can have them repaired for a reasonable price. Nanocom Evo |
It's Not hiding the problem.
Don't replace using copper pipes is the answer. |
Don't replace using copper ? Confused now thought replacing with copper was the way to go ? Nanocom Evo |
Edited my post above yours, use Kunifer. John
Jock 77 Member Since: 13 Apr 2012 Location: Falkirk Posts: 187 ![]() ![]() ![]() |
Hi Jaggs
Thanks for the info guys, definitely will be getting them done, I'll ring Agee Indys tomorrow Nanocom Evo |
