Home > Technical > Corroded front to rear brake pipes
Jaggs
Had the RRS in for its 9 year service, front to rear pipes are badly corroded according to health check, quote of 350 plus vat but maybe more if they can't "unscrew" the joints due to corrosion.
Can any one recommend an Indy in West Yorkshire or mobile mechanic who cold do this for a more reasonable price, seems expensive for a few meters of pipe work. The garage state they would fail he MOT if it was due so need to look at having them done. Prefer landrover specialist but I guess the brake lines are same on most cars. Nanocom Evo
Post #502010 Tue Aug 02 2016 6:14pm
Tyrefitter
That's expensive for 2 brake pipes,we charge £40 per pipe.its only £10 for a roll of copper pipe & you would probably be able to do full car with one roll.
Andy. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #502011 Tue Aug 02 2016 6:21pm
Jaggs
Is it something you can do Andy, happy to travel and wait Smile Nanocom Evo
Post #502012 Tue Aug 02 2016 6:30pm
Have you done a RRS before ?
I think access is a pain at the rear.
You could always clean them off and coat with oil etc.
Post #502019 Tue Aug 02 2016 7:43pm
Jaggs
Don't really want to hide the problem, if the pipes fail its a lot of car to stop but feel sure I can have them repaired for a reasonable price. Nanocom Evo
Post #502021 Tue Aug 02 2016 7:51pm
It's Not hiding the problem.
It's preventing it rusting or slowing it down.
Post #502023 Tue Aug 02 2016 8:26pm
Johnski
Don't replace using copper pipes is the answer. Wink
Copper is cheaper but I use Kunifer its about twice the price, but still not the price you have been quoted, I paid £270 on my last car. John
Post #502026 Tue Aug 02 2016 8:29pm
Jaggs
Don't replace using copper ? Confused now thought replacing with copper was the way to go ? Nanocom Evo
Post #502027 Tue Aug 02 2016 8:33pm
Johnski
Edited my post above yours, use Kunifer. John
Post #502028 Tue Aug 02 2016 8:34pm
Jock 77
Scotland 2006 Range Rover Sport TDV6 HSE Java Black
Re Brake Pipes
Hi Jaggs
I had mine replaced a couple of years ago as it actually failed as they go up and over the Chassis at the back. I was towing an Ifor Williams trailer with a Frontera on it at the time,Luckily only a pinhole in the pipe and low fluid light came on.
I put it in to get done think I was around £220 ,I was told they are common for this. Access is a pita as heatshield's etc need to be removed and think it helps greatly to have Ramp access below the car.
Hope this helps.
Jock Thumbs Up
Post #502031 Tue Aug 02 2016 8:47pm
Jaggs
Thanks for the info guys, definitely will be getting them done, I'll ring Agee Indys tomorrow Nanocom Evo
Post #502035 Tue Aug 02 2016 9:12pm
