![]() | Home > Maintenance & Modifications > LED HALO DRL |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5120 ![]() ![]() ![]() |
I would connect yellow to dip beam at the headlight. |
tanloverluke Member Since: 19 Mar 2013 Location: Honiton Posts: 917 ![]() ![]() ![]() |
do you want the angel eyes to come on when the ignition is turned to on, or only when the headlights are on? if the former, then try to wire the yellow into the fusebox and see if this works (which it should). there are several write-ups about the best slot. Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
look at my post here: http://www.rrsport.co.uk/forum/post441576.html#441576 Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Whether they are on is automatically detected by the voltage of the engine running.
Gilly1 Member Since: 29 May 2015 Location: Somerset Posts: 203 ![]() ![]() ![]() |
Yes they are engine On/off recognition, I just piggy backed left headlight Dip beam fuse to try them and it works a treat, I start engine and approx 5 seconds later they illuminate, switch lights on and they don't go off they reduce brightness 50% and when I turn car off there is approx 10 second delay then they go out. So I think the set up Iv got is exactly how Andy suggests, so now it's just a case of finding the correct dip beam headlight wire to tap into under bonnet. Thanks Andy, |
Dip beam is pin 11 on the headlight connector.
Awesome, thanks Andy. |
Not the best pic but DRL,S fitted,
tommymac Member Since: 18 Oct 2018 Location: lancaashire Posts: 13 ![]() ![]() ![]() |
hi gilly,
jason-nike Member Since: 08 Nov 2013 Location: sussex Posts: 207 ![]() ![]() |
Heres mine I fitted on my last RRS
RUSK Member Since: 27 Nov 2018 Location: South West Posts: 63 ![]() ![]() ![]() |
I love the look of this - reminds me of my old BMW... are there any kits or conversions like this, suitable for someone with the technical prowess of a sausage roll to fit?
I fitted mine myself.
Joe Hankey Member Since: 16 Apr 2016 Location: warrington cheshire Posts: 117 ![]() ![]() ![]() |
Just looking for someone to do my car. I live in warrington. So it would be someone in the manchester/liverpool. Area but open to go somewhere else if needed. Any help would be much appreciated. |
