Home > Maintenance & Modifications > LED HALO DRL
Gilly1
LED HALO DRL
hi, wanting to do halo ring mod, can anyone help with wiring instructions, shall I just piggy back a fuse, Iv briefly connected wires to battery and yellow to interior light and when unlock they come on and when I lock the go out a few seconds later. But not sure that is the correct way to do or not. Apparently the seller States that with the wiring kit they will recognise when engine is started and light up and when auto lights come on they will go out or when turn engine of whatever happens first.
Post #500383 Fri Jul 08 2016 3:33pm
I would connect yellow to dip beam at the headlight.
Post #500389 Fri Jul 08 2016 5:59pm
tanloverluke
do you want the angel eyes to come on when the ignition is turned to on, or only when the headlights are on? if the former, then try to wire the yellow into the fusebox and see if this works (which it should). there are several write-ups about the best slot. Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights.
TO DO: color code sills and pillars.
Post #500405 Fri Jul 08 2016 11:24pm
tanloverluke
look at my post here: http://www.rrsport.co.uk/forum/post441576.html#441576 Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Post #500406 Fri Jul 08 2016 11:29pm
Whether they are on is automatically detected by the voltage of the engine running.
I assume the yellow wire disables them when lights are on.
Post #500413 Sat Jul 09 2016 6:20am
Gilly1
Yes they are engine On/off recognition, I just piggy backed left headlight Dip beam fuse to try them and it works a treat, I start engine and approx 5 seconds later they illuminate, switch lights on and they don't go off they reduce brightness 50% and when I turn car off there is approx 10 second delay then they go out. So I think the set up Iv got is exactly how Andy suggests, so now it's just a case of finding the correct dip beam headlight wire to tap into under bonnet. Thanks Andy, Thumbs Up And thanks for all replies. Thumbs Up
Post #500414 Sat Jul 09 2016 8:20am
Dip beam is pin 11 on the headlight connector.
This is the blue/orange wire on the RHS headlight
blue/purple? on the LHS headlight
Post #500427 Sat Jul 09 2016 11:20am
Gilly1
Awesome, thanks Andy. Thumbs Up
Post #500447 Sat Jul 09 2016 1:34pm
Gilly1
Not the best pic but DRL,S fitted,
Post #500824 Thu Jul 14 2016 5:50pm
tommymac
United Kingdom 2007 Range Rover Sport TDV6 HSE Zermatt Silver
hi gilly,
was this hard to fit into the actual healight itself? ive just purchased some...
Post #568020 Thu Nov 01 2018 8:49am
jason-nike
Heres mine I fitted on my last RRS
Post #568096 Thu Nov 01 2018 11:32pm
RUSK
I love the look of this - reminds me of my old BMW... are there any kits or conversions like this, suitable for someone with the technical prowess of a sausage roll to fit?
(Although, if I'm honest, I would simply buy the parts and get my garage to sort it...)
Post #572405 Fri Jan 04 2019 8:01pm
jason-nike
I fitted mine myself.
Headlight in oven 190 degrees for 3 mins, then prised lenses apart, then glued rinds to existing headlights, then ran wires out the back of the headlight
Post #574066 Tue Jan 29 2019 5:37pm
Joe Hankey
England 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Lights
Just looking for someone to do my car. I live in warrington. So it would be someone in the manchester/liverpool. Area but open to go somewhere else if needed. Any help would be much appreciated.
Post #575585 Tue Feb 19 2019 11:32pm
