![]() | Home > General (L494) > Tyre size L494 |
DaveW Member Since: 14 Nov 2013 Location: Warwickshire Posts: 283 ![]() ![]() |
Standard L494 offset is 49mm, SVR is 42.5.
IRBails Member Since: 22 Nov 2013 Location: Wollongong Posts: 872 ![]() ![]() |
Dave I knew I was going to pull the wheel in but I didn't think 4 mm was such a big deal. My fault as I did not bother to look. Anyway 1 mm of clearance would not bother me but the the side with virtually no clearance does so I'll chase up some 3mm spacers, hopefully there is sufficient thread for this Solution to be secure. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
I think at 3mm you should be ok. I'm fairly sure there's sufficient thread engagement on the studs but probably worth checking somewhere.
Yes Wollongong Wiz I think they called Wayne , also the home of Troy Corser . Used to be an industrial city 80 k's south of Sydney , but now is basically a suburb of Sydney. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
