![]() | Home > Technical > Red Park Brake Warning Flashing on Dash |
Have you had a look under the car to check you haven't damaged anything around the EPB, especially as you also shredded a tyre? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5115 ![]() ![]() ![]() |
Worth a read
alpaca Member Since: 09 Sep 2014 Location: Silicon Valley Posts: 83 ![]() ![]() ![]() |
Thanks - I checked underneath, nothing is obviously damaged - the brake light started flashing after a few miles off road on dusty trail - but nothing too bumpy. That was before the river crossing and tire incident ! I looked at the other thread you linked me to - will check the connectors / fuses this weekend and use some contact cleaner ... see if that helps ... |
check for the chafed wires too |
Update
