Home > Maintenance & Modifications > CLAY BAR?
andrew kennedy
France 2006 Range Rover Sport TDV6 HSE Maya Gold
CLAY BAR?
My Sport is 10 years old and just under 100,000 miles on the cloth. Sections of the car external body work i.e.lower section of all four doors are rough to the touch. I've have just washed, cleaned all these areas and waxed them but the surface is still have a 'orange peel feel' to the touch. Is this where a Clay Bar can be used ?!? Any advice please Andrew Kennedy
Post #498100 Tue Jun 07 2016 12:14pm
Humm...
I would usually clay bar flat surfaces (bonnet) and would do this first with a new clay bar.
Yes you could clay the lower surfaces once you have used the clay on the rest of the body work.
Post #498102 Tue Jun 07 2016 12:19pm
Paddi
Are you sure it is not tar spots you can feel? It is recommended to remove tar spots before using a clay bar. Autoglym Intensive Tar Remover works pretty well and there are many other products that do the same job. 2008 MY Java Black TDV8 HSE
Post #498104 Tue Jun 07 2016 12:45pm
andrew kennedy
Thanks for yours!! Just had a closer look, it could be tar although some of the rough patches don't appear to be black? Andrew Kennedy
Post #498106 Tue Jun 07 2016 1:36pm
Danv8
United Kingdom 2009 Range Rover Sport TDV6 HSE Lux Alaska White
Buy your self some tar remover and fall out remover, after washing dry the areas, spray with tar remover, let dwell for a few minutes, possible some agitation may be required then wash off and dry, then spray on the fall out remover, this will remove in ground debris such as iron filings, rail dust, brake pad dust, depnding on the colour of your car you can easily see this working as the chemicals turn the contaminants pink, then wash and rinse, then use your clay bar, and make sure you use plenty of lube with it. Some say water is more than adequate, but i would either use a detailing spray, a dedicated clay bar lube or make a solution of water and car shampoo 75% water 25% shampoo.
ps if you cant find tar remover, wd40 works but takes a bit more effort to wash off afterwards.
I had to do a full decontamination on mine as i hadnt done it for a while, I wash an dried and it looked spotless, then applied the fallout remover ( no visable tar) and this surprised me. Then clayed it afterwards for a super smooth finish
[URL=]
[/URL]
finished shot
[URL=]
[/URL]
Post #498118 Tue Jun 07 2016 3:28pm
Tyrefitter
I use a clay cloth instead of the bar,if you drop the bar on the floor you have to bin it but with the cloth you can just rinse & use again & again.
Andy Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #498141 Tue Jun 07 2016 7:11pm
cloths are faster too Thumbs Up
Post #498144 Tue Jun 07 2016 7:59pm
Arh. Didn't know about the cloths.
Would you recommend any brand?
Post #498149 Tue Jun 07 2016 8:48pm
Danv8
In Halfords you can get a clay mit, Farcela G3, its ok, i have one but still go back to a clay bar.
Artdeshine do a clay cloth, currently sold out
http://www.obsessiveshine.com.au/products/artdeshine-clay-cloth
Just found these guys
http://www.theclayclothcompany.co.uk/oursh...reign.html
They have plenty of you tube vids as well.
Post #498207 Wed Jun 08 2016 2:50pm
CANROVER
Canada 2010 Range Rover Sport Supercharged Santorini Black
I Clayed mine and it is now baby smooth all around..... Except the rear bumper and hatch. It's a big car!!!! I'll do it tomorrow and take some pics. It's really not that hard and I didn't even use the quick detailer. I just over soaped the water with meguires wash' wax and made sure the paint was super sudsy while claying. There's a lot of videos on YouTube. This is the one that made me get more comfy with claying.
Post #498261 Thu Jun 09 2016 3:31am
