![]() | Home > Maintenance & Modifications > CLAY BAR? |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5049 ![]() ![]() ![]() |
Humm...
Are you sure it is not tar spots you can feel? It is recommended to remove tar spots before using a clay bar. Autoglym Intensive Tar Remover works pretty well and there are many other products that do the same job. 2008 MY Java Black TDV8 HSE
andrew kennedy Member Since: 27 Apr 2010 Location: brittany Posts: 338 ![]() ![]() ![]() |
Thanks for yours!! Just had a closer look, it could be tar although some of the rough patches don't appear to be black? Andrew Kennedy |
Danv8 Member Since: 20 Apr 2015 Location: Norfolk Posts: 378 ![]() ![]() ![]() |
Buy your self some tar remover and fall out remover, after washing dry the areas, spray with tar remover, let dwell for a few minutes, possible some agitation may be required then wash off and dry, then spray on the fall out remover, this will remove in ground debris such as iron filings, rail dust, brake pad dust, depnding on the colour of your car you can easily see this working as the chemicals turn the contaminants pink, then wash and rinse, then use your clay bar, and make sure you use plenty of lube with it. Some say water is more than adequate, but i would either use a detailing spray, a dedicated clay bar lube or make a solution of water and car shampoo 75% water 25% shampoo.
I use a clay cloth instead of the bar,if you drop the bar on the floor you have to bin it but with the cloth you can just rinse & use again & again.
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
cloths are faster too |
Arh. Didn't know about the cloths.
In Halfords you can get a clay mit, Farcela G3, its ok, i have one but still go back to a clay bar.
CANROVER Member Since: 03 Oct 2015 Location: Ottawa Posts: 255 ![]() ![]() ![]() |
I Clayed mine and it is now baby smooth all around..... Except the rear bumper and hatch. It's a big car!!!! I'll do it tomorrow and take some pics. It's really not that hard and I didn't even use the quick detailer. I just over soaped the water with meguires wash' wax and made sure the paint was super sudsy while claying. There's a lot of videos on YouTube. This is the one that made me get more comfy with claying.
