Home > Faults & Fixes > Dilema |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 919 |
If the issues will be covered by the garage have it sorted and enjoy the car,, it's at the age when certain things will start to go wrong. Restricted performance could be egr valves,, easy fix on a V6 and then you can forget about them especially if someone else is paying! 2010 RRS, TDV8
Thu May 26 2016 9:07pm |
Jimbob36 Member Since: 13 May 2016 Location: Melton mowbray Posts: 74 |
So car has behaved perfectly since its initial message. Drive to game fair this morning and it didn't feel quite right. Got the impression I was giving it more throttle than yesterday and couldn't put my finger on it. Left this afternoon and got 5 miles before restricted performance pinged up, just as I was joining the a1 in front of a lorry! Not ideal! Carried onto field approx 15 miles and turned off. Was fine after leaving for half hour but still doesn't feel right. I'm thinking egr but I'll let garage decide. Worked for landy dealer from 2004 to 2008 so quite aware of issues we experienced. |
Sun May 29 2016 5:34pm |
Had mate stick car on his sdd system. Cms 4x4 near Melton Mowbray. P2263 logged twice matching occurrences encountered. Next step into garage to sort along with wheel vibration. |
Wed Jun 01 2016 9:04pm |
Johnski Member Since: 02 Sep 2015 Location: North Wales & North Yorkshire Posts: 1407 |
That could simply be down to needing a four wheel alignment and wheel balance check. John
Wed Jun 01 2016 10:42pm |
Update.
Fri Jun 10 2016 9:32pm |
Fault has reappeared! Garage replaced turbo change over valve. I've been away on business for 4 weeks so wife has only done approx 1000 miles since car was repaired. Just off on holiday and get 80 miles, ping, restricted performance and same symptoms as before. Didn't feel right this morning. Erratic throttle, snatch pulling away from junctions. I've phoned dealer and emailed rejecting the car. Don't want this hassle and worry every time we drive it. Done 1400 miles in 2 months. Where do we stand with a refund? |
Sat Jul 23 2016 9:08pm |
Orange RRS Member Since: 24 May 2016 Location: Lincolnshire Posts: 89 |
I think you have 1 month to reject the vehicle if the supplying garage can't fix the fault. This is in the new consumer laws brought in last October, but if the dealer supplied a warranty I am led to believe this doesn't apply. Life's too short to drive boring cars !
Sat Jul 23 2016 9:41pm |
I do not know at present, obviously the car is not fit for purpose, so you should be able to either get another replacement, or your money back, but you may get slightly less as you have down a mileage on it, and the garage has "appeared" to be trying to sort the various problems. I would also consult with trading standards, to get advice and assistance in getting what you want.
Sat Jul 23 2016 9:55pm |
So the garage has decided that the turbo is at fault and it's been sent to a repair centre. I'm dubious of such repairs being successful due to the nature of vnt turbos. If I get it back and it faults again, legally where do I stand? I have fault code printout showing codes prior to purchase for multiple engine related issues and I have lost confidence in it completely! The wife doesn't want to drive it at all now too! Can I get a refund? Had it for 2 months and done approx 1300 miles, with 200 done by garage and collecting/delivering it back to us.lovelly car so disappointed is an understatement. It may be perfectly fine when it comes back but the experience so far has been somewhat tainted. If I can get out of it, I think I will. |
Mon Aug 01 2016 8:40pm |
