Home > Maintenance & Modifications > Just bought these off ebay... Brembo Calipers! Are these ok?
sean2204
Ok, so I'm going ahead with the Brembo brake conversion and thought these were too good not to buy...
http://www.ebay.co.uk/itm/201581312645?_tr...EBIDX%3AIT
I did check with the seller before buying that they'd fit my 2012 RRS HSE Lux Overfinch and he said they should just bolt on. Can anyone on here confirm these are the right ones for me, and if so, will the following pads and discs ok...?
http://www.ebay.co.uk/itm/271909402514?_tr...EBIDX%3AIT
If the above are ok do I just need the rear Calipers and dust covers?
Thank you
Sean
Post #495998 Sat May 14 2016 6:53pm
Those are not the correct discs and pads 6 Pot brembos use 380/385 mm discs not 360mm they are 4 pot one's.
Post #496001 Sat May 14 2016 7:00pm
Disco_Mikey
The above is correct
Post #496002 Sat May 14 2016 7:34pm
sean2204
Thank you guys. I will not be buying those then!
Are the 6 pot calipers correct at least? I've already bought these Shocked
Thank you
Sean
Post #496006 Sat May 14 2016 7:50pm
Disco_Mikey
They do appear to be correct Thumbs Up
Swap you for a set of 4 pots Whistle
Post #496007 Sat May 14 2016 7:56pm
sean2204
That's great, cheers.
Sorry... I need to attempt the conversion first. I'll be probably mess it up mind Rolling Eyes
Daft question, but for the 380mm discs is it best to buy Brembo ones? I've had a look on eBay and can only see unbranded ones such as this... http://www.ebay.co.uk/itm/Land-Rover-Range...Sw5HJXKUqH
Thank you again!
Sean
Post #496008 Sat May 14 2016 8:10pm
Disco_Mikey
Those discs are for an FFRR Thumbs Up
Post #496010 Sat May 14 2016 8:20pm
sean2204
Ah so no good then?
Post #496013 Sat May 14 2016 8:52pm
Disco_Mikey
No, you need them for an RRS Wink
Post #496014 Sat May 14 2016 8:53pm
sean2204
Can you tell I'm a novice yet?!
Really appreciate your help with this. The search continues.
Post #496015 Sat May 14 2016 8:57pm
L/R Part Numbers.
http://www.ebay.co.uk/itm/RANGE-ROVER-RANG...SwgQ9ViAVv
Discs LR016176
http://www.ebay.co.uk/itm/Genuine-Range-20...Swu4BVr7V9
Pads LR020362
Post #496016 Sat May 14 2016 9:08pm
sean2204
Thanks Col that's a massive help.
Post #496020 Sat May 14 2016 9:32pm
