![]() | Home > Maintenance & Modifications > Just bought these off ebay... Brembo Calipers! Are these ok? |
sean2204 Member Since: 05 Mar 2016 Location: York Posts: 55 ![]() ![]() |
Ok, so I'm going ahead with the Brembo brake conversion and thought these were too good not to buy...
Those are not the correct discs and pads 6 Pot brembos use 380/385 mm discs not 360mm they are 4 pot one's.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4521 ![]() ![]() ![]() |
The above is correct |
They do appear to be correct |
That's great, cheers.
Those discs are for an FFRR |
Ah so no good then? |
No, you need them for an RRS |
Can you tell I'm a novice yet?!
L/R Part Numbers.
Thanks Col that's a massive help. |
