![]() | Home > Maintenance & Modifications > RRS MY12 Brake upgrade |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 960 ![]() ![]() ![]() |
If your looking for someone to carry out the work check out Quattro auto are they are in Riccall which is right on your doorstep. As for fitting brembo' s, I think it depends on what size wheels you've got as some of the smaller ones will not fit over the bigger calipers. I' m sure there are a few threads on this subject. 2010 RRS, TDV8
That should be Quattro autocare, stupid predictive text |
sean2204 Member Since: 05 Mar 2016 Location: York Posts: 55 ![]() ![]() |
Thanks gogsy.
Minimum size wheels are 19 or 20 inch, do a search on here for brembo upgrade,,, lots of info and part numbers 2010 RRS, TDV8
deano_123 Member Since: 13 Aug 2015 Location: Newcastle Posts: 108 ![]() ![]() |
Discs are known to warp due to people sitting with their foot on the brake in traffic causing hot spots following braking.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4527 ![]() ![]() ![]() |
A 2012 RRS already has Brembo sized discs + pads. All you would be gaining is some visual stimulation |
I'm pretty sure mine doesn't have Brembo discs and pads. It's a 2012 HSE Lux SDV6... |
