Home > Maintenance & Modifications > RRS MY12 Brake upgrade
sean2204
Hi guys, after some help again please...
When braking I get a bit of wheel wobble through the steering wheel so I'm thinking the discs and pads need changing. Reading other threads it looks like these can be upgraded to the SC Brembo set... is this correct?
Daft question, but is this something the main dealer would do for me? If not, can someone recommend a company in North Yorkshire who could assist?
thank you
Post #494720 Fri Apr 29 2016 7:51am
gogsy1956
If your looking for someone to carry out the work check out Quattro auto are they are in Riccall which is right on your doorstep. As for fitting brembo' s, I think it depends on what size wheels you've got as some of the smaller ones will not fit over the bigger calipers. I' m sure there are a few threads on this subject. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #494726 Fri Apr 29 2016 11:46am
gogsy1956
That should be Quattro autocare, stupid predictive text Confused 2010 RRS, TDV8
22" overfinch
Post #494727 Fri Apr 29 2016 11:48am
sean2204
Thanks gogsy.
I have 22" Overfinch Olara wheels.
I'm trawling ebay but really need to get the correct part numbers to ensure I get the right stuff.
Post #494790 Sat Apr 30 2016 5:26pm
gogsy1956
Minimum size wheels are 19 or 20 inch, do a search on here for brembo upgrade,,, lots of info and part numbers 2010 RRS, TDV8
22" overfinch
Post #494796 Sat Apr 30 2016 7:19pm
deano_123
Discs are known to warp due to people sitting with their foot on the brake in traffic causing hot spots following braking.
Upgrade is straightforward as I think its only the diesels that didnt come with Brembo's. For me the standard calipers are sufficient enough to pull up a 2.5 ton brick, replacement pads and discs are just over a ton as opposed to 600 - 700 for a Brembo setup in good condition
Post #494842 Sun May 01 2016 3:54pm
Disco_Mikey
A 2012 RRS already has Brembo sized discs + pads. All you would be gaining is some visual stimulation Thumbs Up
Unless you are talking about the 6 pot upgrade...
Post #494844 Sun May 01 2016 4:09pm
sean2204
I'm pretty sure mine doesn't have Brembo discs and pads. It's a 2012 HSE Lux SDV6...
Post #495996 Sat May 14 2016 6:09pm
