| RRSPORT.CO.UK | ||
|  | Home > Technical > RRS TDV8 issues - advice needed |
| TheWojtek Member Since: 08 May 2015 Location: PoznaĆ, Poland Posts: 752      | CD - I'd try a cleaning CD, but wouldn't hold my breath.
|  Wed Apr 27 2016 6:26pm |
| Tim in Scotland Member Since: 30 May 2005 Location: Driving along in my automobile Posts: 17476    | Check your brake light lamps are both working, often a blown lamp can throw up lots of alarms and warnings. Also carry out a a hard reset - there are loads of instructions how to do it if you use the search function 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
|  Wed Apr 27 2016 6:29pm |
| HemoRRS Member Since: 31 Mar 2016 Location: Wolverhampton Posts: 254      | Alarm going off is probably relating to the bonnet open message.
|  Wed Apr 27 2016 6:45pm |
| Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380      | HI, was it a genuine replacement alternator ?? i had more or less the same thing and a hard reset with a new battery done the trick. Hope this helps   | ||
|  Wed Apr 27 2016 8:14pm |
| Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380      | Hi again, my alternator replacement was a Denso and works fine, but there's plenty of rubbish out there and RRS are very fussy what they wear   | ||
|  Wed Apr 27 2016 8:17pm |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | Bonnet open message/alarm sounding is almost certainly the bonnet catch switch. Cheap and easy to fix.
|  Thu Apr 28 2016 8:46am |
| Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477    | Many of your symptoms are are commonly associated with voltage issues, and others (alarm, bonnet catch, door) are linked by the BCM (Body Control Module) which can be upset by electrical noise on the brake circuits, so as said above, keep the battery and alternator in mind and consider changing the brake bulbs and switch. My bet is on the battery as above.  | ||
|  Thu Apr 28 2016 9:03am |
| DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2025    | These guys have a good reputation if you're struggling:
|  Thu Apr 28 2016 11:09am |
| GloriousGunner Member Since: 27 Apr 2016 Location: Warwickshire Posts: 8      | Thanks for all the feedback, really appreciate it. Thought I'd share the outcome based on the advice given :
|  Mon May 16 2016 1:36pm |
| GloriousGunner Member Since: 27 Apr 2016 Location: Warwickshire Posts: 8      | Thanks HemoRRS
|  Mon May 16 2016 1:40pm |
 Thanks, yep mine was replaced with a Denso alternator, so all good. Hard reset seems to have sorted most if it. Few other bits still to sort (see other post) RRS TDV8 2008 Stornaway Grey | ||
|  Mon May 16 2016 1:44pm |
 Thanks Dr Rob. Unfortunately they're a bit far away for me, so am using these guys instead : http://www.venture-offroad.co.uk/ RRS TDV8 2008 Stornaway Grey | ||
|  Mon May 16 2016 1:47pm |
 Thanks, checked them, they all seem fine. A hard reset seemed to sort most of it out though, rest is genuine stuff that needs replacing (see other post) RRS TDV8 2008 Stornaway Grey | ||
|  Mon May 16 2016 1:49pm |
 Thanks. Hard rest sorted most of the issues. Checked coolant bottle/float and they're fine. RRS TDV8 2008 Stornaway Grey | ||
|  Mon May 16 2016 1:51pm |
| All times are GMT | < Previous Topic | Next Topic > |
| Posting Rules
