![]() | Home > Technical > RRS TDV8 issues - advice needed |
| TheWojtek Member Since: 08 May 2015 Location: PoznaĆ, Poland Posts: 752
CD - I'd try a cleaning CD, but wouldn't hold my breath.
Check your brake light lamps are both working, often a blown lamp can throw up lots of alarms and warnings. Also carry out a a hard reset - there are loads of instructions how to do it if you use the search function 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
| HemoRRS Member Since: 31 Mar 2016 Location: Wolverhampton Posts: 254
Alarm going off is probably relating to the bonnet open message.
| Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380
HI, was it a genuine replacement alternator ?? i had more or less the same thing and a hard reset with a new battery done the trick. Hope this helps |
Hi again, my alternator replacement was a Denso and works fine, but there's plenty of rubbish out there and RRS are very fussy what they wear |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9155
Bonnet open message/alarm sounding is almost certainly the bonnet catch switch. Cheap and easy to fix.
| Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477
Many of your symptoms are are commonly associated with voltage issues, and others (alarm, bonnet catch, door) are linked by the BCM (Body Control Module) which can be upset by electrical noise on the brake circuits, so as said above, keep the battery and alternator in mind and consider changing the brake bulbs and switch. My bet is on the battery as above. |
| DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2025
These guys have a good reputation if you're struggling:
| GloriousGunner Member Since: 27 Apr 2016 Location: Warwickshire Posts: 8
Thanks for all the feedback, really appreciate it. Thought I'd share the outcome based on the advice given :
Thanks HemoRRS
Thanks, yep mine was replaced with a Denso alternator, so all good. Hard reset seems to have sorted most if it. Few other bits still to sort (see other post) RRS TDV8 2008 Stornaway Grey |
Thanks Dr Rob. Unfortunately they're a bit far away for me, so am using these guys instead : http://www.venture-offroad.co.uk/ RRS TDV8 2008 Stornaway Grey |
Thanks, checked them, they all seem fine. A hard reset seemed to sort most of it out though, rest is genuine stuff that needs replacing (see other post) RRS TDV8 2008 Stornaway Grey |
Thanks. Hard rest sorted most of the issues. Checked coolant bottle/float and they're fine. RRS TDV8 2008 Stornaway Grey |
| All times are GMT |
