![]() | Home > General > Dull headlight lens |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 ![]() ![]() ![]() |
T-cut and abit of elbow grease |
HemoRRS Member Since: 31 Mar 2016 Location: Wolverhampton Posts: 254 ![]() ![]() ![]() |
Wet & dry and soapy water, did mine finished up with 2000 grit. Think I started at 800.
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
The lenses are plastic with a lacquer coat.
Yetiman Member Since: 16 Dec 2015 Location: Tamworth Posts: 25 ![]() ![]() |
Didn't know about the laquer, maybe get the pro's to sort it then.
Bladeboy Member Since: 17 Sep 2013 Location: Benson Posts: 522 ![]() ![]() ![]() |
I've heard toothpaste suggested before- I guess it's quite abrasive too though |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5097 ![]() ![]() ![]() |
Could try Meguiars Plastx plastic cleaner and polish.
CRACKA Member Since: 16 Sep 2014 Location: Hallam Victoria 3803 Posts: 170 ![]() ![]() ![]() |
Yes there are a couple of Lens cleaners out there .They work very well and the better ones have a final protective coating to apply when the job is done. 2006 4.2 S/C with Tow Pack, Side Steps, DRL's, 19" & 20" wheels, additional 110 ltr Fuel Tank Roof Rack and performance mods.
adameverett Member Since: 14 Nov 2015 Location: Warwick Posts: 110 ![]() ![]() ![]() |
Funny, I was in Halfords just last lunch time picked up this
I tried the Meguiars 1 step, that's when I learned about the lacquer. The two step stuff should be better as I'm guessing the second step is a lacquer. |
Just read the instructions on the rear of the PlastX Bottle and it says not to use on coated plastics, so if there is a lacquer coating on the lens I guess that would mean that as well.
Any headlight that's speckled/cloudy means the the top coat has/is coming off.
Ian.H Member Since: 04 Oct 2014 Location: England Posts: 180 ![]() ![]() ![]() |
Polish it either with a machine or toothpaste, then apply a layer of wax over it. Wax the lights when you wash the car again... job's a good'en |
