| RRSPORT.CO.UK | ||
|  | Home > General > Dull headlight lens |
| Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003      | T-cut and abit of elbow grease   | ||
|  Mon Apr 18 2016 12:47pm |
| HemoRRS Member Since: 31 Mar 2016 Location: Wolverhampton Posts: 254      | Wet & dry and soapy water, did mine finished up with 2000 grit. Think I started at 800.
|  Mon Apr 18 2016 12:50pm |
| Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594      | The lenses are plastic with a lacquer coat.
|  Mon Apr 18 2016 1:42pm |
| Yetiman Member Since: 16 Dec 2015 Location: Tamworth Posts: 25    | Didn't know about the laquer, maybe get the pro's to sort it then.
|  Mon Apr 18 2016 7:39pm |
| Bladeboy Member Since: 17 Sep 2013 Location: Benson Posts: 522      | I've heard toothpaste suggested before- I guess it's quite abrasive too though | ||
|  Wed Apr 20 2016 8:23pm |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156      | Could try Meguiars Plastx plastic cleaner and polish.
|  Wed Apr 20 2016 9:59pm |
| CRACKA Member Since: 16 Sep 2014 Location: Hallam Victoria 3803 Posts: 170      | Yes there are a couple of Lens cleaners out there .They work very well and the better ones have a final protective coating to apply when the job is done. 2006 4.2 S/C with Tow Pack, Side Steps, DRL's, 19" & 20" wheels, additional 110 ltr Fuel Tank Roof Rack and performance mods.
|  Thu Apr 21 2016 5:17am |
| adameverett Member Since: 14 Nov 2015 Location: Warwick Posts: 110      | Funny, I was in Halfords just last lunch time picked up this
|  Thu Apr 21 2016 6:37am |
| Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594      | I tried the Meguiars 1 step, that's when I learned about the lacquer. The two step stuff should be better as I'm guessing the second step is a lacquer. | ||
|  Thu Apr 21 2016 8:33am |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156      | Just read the instructions on the rear of the PlastX Bottle and it says not to use on coated plastics, so if there is a lacquer coating on the lens I guess that would mean that as well.
|  Thu Apr 21 2016 8:47am |
| HemoRRS Member Since: 31 Mar 2016 Location: Wolverhampton Posts: 254      | Any headlight that's speckled/cloudy means the the top coat has/is coming off.
|  Thu Apr 21 2016 9:19am |
| Ian.H Member Since: 04 Oct 2014 Location: England Posts: 180      | Polish it either with a machine or toothpaste, then apply a layer of wax over it. Wax the lights when you wash the car again... job's a good'en  | ||
|  Thu Apr 21 2016 9:53am |
| Posting Rules
